Thanks but I changed :)
http://img294.imageshack.us/img294/9...2007563sm6.jpg
Well, i finally think i'm finished with it(other than getting a quad and a fuzion)
http://img485.imageshack.us/img485/4994/PICT4350.jpg
Inside
http://img485.imageshack.us/img485/5417/PICT4352.jpg
http://img485.imageshack.us/img485/8653/PICT4354.jpg
dual color leds FTW
http://img485.imageshack.us/img485/1/PICT4333.jpg
http://img485.imageshack.us/img485/5430/PICT4335.jpg
http://img485.imageshack.us/img485/5452/PICT4334.jpg
http://img485.imageshack.us/img485/8048/PICT4341.jpg
More @ http://picasaweb.google.com/smopuim86/V2100Updated
and http://picasaweb.google.com/smopuim8...AndWatercooled
Man every time I see that p180 build, I want it more :p:
[QUOTE=smopoim86;2074049]Well, i finally think i'm finished with it(other than getting a quad and a fuzion)
that has got to be a PITA to fill that t-line..
I think that T-line runs to a res... shouldnt be that bad if he fills the res and runs the pump for a couple seconds, fill the res again...
EDIT: Just saw the T-line in the bottom... I think its in the bottom so its easy for him to drain out the loop. Look at the top of the case in the front, there is a fillport running to the res.
Here is mine mid tower, I did like the one from Martinii (page 113) so it's very similar.
http://img152.imageshack.us/img152/8...rontsn7.th.jpg
http://img133.imageshack.us/img133/6...ted1ef4.th.jpg
http://img405.imageshack.us/img405/2...ntedvg7.th.jpg
I do have a problem with my OCZ, I thought that connecting them will reduce the liquid flow. Shall I put another pump-reservoir and add the graphic card or just connect also the memory?? The space is very limited.....
Hi all, this is my PC.
Hardware:
Asus A8N32 SLI Deluxe
E-VGA 7800GT + XFX 7800GT
AMD 64 3500+ Clawhammer :(
2x512 Corsair value
Creative Audigy 2 Platinum
Maxtor SATA 120GB + 160GB + 320GB
Tagan 480-U01
TT Armor
H2O cooling:
Pompa MCP655
WB Lunasio Air X-Force R1
Bobble X-Trap-6515/Pro
Global view:
http://www.atris.it/Forum/photoplog/...1_DSCF6631.JPG
In view:
http://www.atris.it/Forum/photoplog/...1_DSCF6636.JPG
http://www.atris.it/Forum/photoplog/...1_DSCF6683.JPG
http://www.atris.it/Forum/photoplog/...1_DSCF6617.JPG
Position of Bobble:
http://www.atris.it/Forum/photoplog/...1_DSCF6610.JPG
http://www.atris.it/Forum/photoplog/...1_DSCF6637.JPG
http://www.atris.it/Forum/photoplog/...1_DSCF6634.JPG
Fix the radiator
http://www.atris.it/Forum/photoplog/...1_CIMG1239.JPG
Little test:
http://www.atris.it/Forum/photoplog/...ature_32MB.JPG
no its HIS chip.. he sent it me :P
Here is my loop, all my components are in my sig. The pics with blue liquid was the PC ICE uv blue. Not that uv reactive. The pics with the red liquid is the new fluid XP+ EXT blood red. Cools much better then the PC ICE.
http://img.photobucket.com/albums/v7...e/DSC01225.jpg
http://img.photobucket.com/albums/v7...e/DSC01231.jpg
http://img.photobucket.com/albums/v7...e/DSC01229.jpg
http://img.photobucket.com/albums/v7...e/DSC01232.jpg
http://img.photobucket.com/albums/v7...e/DSC01266.jpg
http://img.photobucket.com/albums/v7...e/DSC01317.jpg
http://img.photobucket.com/albums/v7...e/DSC01318.jpg
http://img.photobucket.com/albums/v7...e/DSC01322.jpg
www.aquatuning.de the mips were not in stock so had to wait couple of weeks, but it worth it to wait.
The mosfet block are made by LUNASIO http://www.lunasio-cooling.com/catal...86e83fef6b694e glued with thermal bi-component mixed with thermal paste artic silver.
So do you think reducing from 8mm to 6mm will not reduce the flow? I ' ll give a try otherwise I 'll put another pump with small reservoir
italian soldier, what res is that?
The tube have inside the spiral ;)
My res is:Quote:
Originally Posted by GuitarFreak1857
Lunasio Bobble X-Trap-6515/Pro
still under construction...some nightshots :
http://img465.imageshack.us/img465/2196/redtest1pv0.jpg
http://img74.imageshack.us/img74/6084/redtest3ge0.jpg
http://img74.imageshack.us/img74/5060/redtest5kb2.jpg
That first picture... watch out for a possible kink between the MOSFET blocks... looks like it might.
