There is another sisoft entry for "non-existent" Opteron ES 16C @ 2.6Ghz. This time results are even better than the last time when the model was listed as running at 2334Mhz. Now it is listed at 2.6Ghz and scores are almost proportionally higher.
Details for Device 2x AMD Opteron 6282 SE
Processor Arithmetic Benchmark 2x AMD Opteron 6282 SE @ 2.6Ghz 243.275GOPS (previous score @ 2.34Ghz was 231.9Gops )
Processor Multi-Media Benchmark 2x AMD Opteron 6282 SE @2.6Ghz 628.234Mpix/s (previous score @ 2.34Ghz was 585.9Mpix/s)
It appears that Turbo is not functional and newest integer throughput results for 4x Opteron 6272 @ 2.1Ghz confirm this ( it scores 377.7 GOPs with 2x more cores => 377.7/2=188.8Gops for 32 cores @2.1Ghz clock? => 188.8 x 2.6/2.1Ghz= 233.8Gops or virtually the same as "non-existent" 2x Opteron 6282SE @ 2.6Ghz ).
For comparison with MC 2P system @ 2.5Ghz :
Processor Arithmetic Benchmark 2x AMD Opteron 6180 SE @2.5Ghz 202.098GOPS
Processor Multi-Media Benchmark 2x AMD Opteron 6180 SE @2.5Ghz 331.207Mpix/s
Note that Turbo appears to be not working for integer throughput test in the case of 6282SE @ 2.6Ghz. Still it is faster than 2.5Ghz MC system by a good 243/202=1.2 or 20% in Processor arithmetic test and 628/332=1.89 or 90% faster in Multimedia test. Multimedia test uses AVX in case of new Opteron which gives around 11% better results on Bulldozer versus SSE test. So 1.89/1.11=1.7 or 70% faster than MC in legacy SIMD (SSE) throughput.
Looking at these latest numbers for 6282SE (which is supposed not to exist according to AMD :) ), FX 8150 @default with Turbo should be in the ballpark of : ~86-90GOPs and 205-210Mpix/s(184-189Mpix/s if you don't use AVX but SSE), in the arithmetic and MM tests, respectively. For comparison 1100T @ def. gets ~66.6 GOPs and 110-115 Mpix/s.
edit: note that these are still "ES" results and not from a retail/final platform
