When I think Koolance I think "trash"
Then you are mistaken. Do some research and actually look into their products. Lesson was learned and fixed and never looking back. They revolutionized the quick disconnect and actually made them into a great product for the LC community. No more ugly ass drain and fillports drilled into uber expensive cases.
While I dont really think the R3E Koolance block is for me (I went EK) I never discount them because of the name.
I have a problem..
Got a brand new r3e.. and now it wont boot :/ the ledfans in my case just blink at me is all !..
Ive got everything connected right. using 1 8pin using 2 8 pin, changed mems, tried 1, 2 and 3 in memsocket.
tried with soundcard and without.. got the cpu and motherboard block on! loosend the cpu one a bit aswell. Still same :/
Check your Q-Connector , if you're using it or check your "Pwr" connector to the motherboard. It's probably upside down? Something is seated incorrectly or all the way in. Your 24 main power isn't connected tight enough... check RAM... lastly.. turn your power supply on.. :)
Did it boot with stock NB heatsink assy on? I always take the time to test a new board fully on air before I put all my blocks on. Nothing worse then spending all the time to get your blocks on perfectly and have no boot.
And the R3E I had die on me did the same thing. It would try to power on for a sec or two then kinda gimp out. Ended up RMAing. Nice thing is I got a new retail box back. I was quite happy since the only other Asus RMA I ever had they send the board back to me with a "nothing to fix" sticker on it. Man that p|ssed me off.
No! thats the bad thing about it :/ ive hooked up everything from the start.. never thought of testing it first :/
I did get a boot into bios just now ! then i thought ok fixed.. tried rebooting same :banana::banana::banana::banana: !!!!
Now tried 5x allready again no boot. wth :/
Not sure this will help. But I encounter that with R2E.
1. Clear CMOS
2. Unplug all cable.
3. Remove all your RAM. PCIe....
4. Remove your cmos battery and wait for 5-10 mins and insert back the battery.
5. Put back everything and boot it up.
Hope it help. At least my last R2E having the same issue as you.
Nothing wrong with your english.. ive tried to boot 1st and 2nd bios also tried to update bios trough rog connect ..
this is surely a power issiue.. cant think of anything else.. but where is the problem :banana::banana::banana::banana: :banana::banana::banana::banana: :banana::banana::banana::banana: :P
Quit all grafics, memory, conector disks...
Connect speaker...
Start yes... no ? sound speaker ?
bah no luck >_<
The only thing that has been 'decent' in their recent history is their cpu block. And even that was a piece of crap because it was so restrictive. I've done the research.
Sure they do quick connects, but all they did was shrink car technology. Nothing more. They're not innovative. They're cheap copycats.
You can tell no lesson was learned because of the position of the outlet barb on their northbridge block. Not to mention I think the full shiny polished top is terrible looking. The inside of my computer case isn't Puerto Rico.
I'm not discounting them because of the name, I'm discounting them because they've sucked for their entire history. Sell me something that's easy to use, and useful.
Ok you have made your point! you dont like Koolance.. Got it! :up: .. move on ?
Anyway.. I thought i was gonna lose my mind ., but got my prob fixed..
It was my case fanns causing the problem.. i disconnected them and booted my pc and it booted.. so i then connected them 1 by one and now got it fixed pffffweh..
Tnx all for trying to help me !!!!
Edit : my NB used to be 63 now 33
my SB used to be 59 now 31
Damn, those NB SB temps are GREAT!, I really think I should Reseat my blocks, god knows How much TM i applied... and also how bad the contact is. EK really pissed me off with the mobo block though, the little black spacers...... Took me 30 minutes to figure out that you weren't supposed to put 2 spacers on these 2 holes.. :/
me on the R2E and R3E now (WaterCooling) I always had the SB a bit hotter than the NB
this is normal?
Is it possible these numbers northbridge/southbridge to be true ?
