This might help me stabilize my 800 ram at 950mhz... it's + or - up to 350ps in 50 intervals... do I do + or - to increase stability vs. performance?
ok i think i used -250ps.... it did help in getting higher memory speed but i m not sure if it helps in performance as i was busy insulating the mobo :)
will test it and let u all know later tonite
Yes 1004 can do it and also the rampage formula bios 0214/0219
Using bios official 1004 here is my 4.GHz STABLE settings.
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : Auto
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 445
PCI-E Frequency: 100
DRAM Frequency: DDR2-1069
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : Auto
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
Ai Clock Twister : Strong
Transaction Booster : Disabled
Relax level: 0
CPU Voltage : 1.30000v real 2.8v
CPU PLL Voltage : Auto
North Bridge Voltage : 1.47
DRAM Voltage : 2.10
FSB Termination Voltage : 1.40
South Bridge Voltage : 1.050
CPU GTL Reference : 0.63X
North Bridge GTL Reference : 0.67X
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : DDR2-REFF
SB 1.5V Voltage : 1.5
http://img262.imageshack.us/img262/205/stableyr7.th.png
Hmmmm... If I set FSB Strap to North Bridge : 400, my memory set ~1151MHz something like that, but windows doesn't boot. My dominator ver is 4.2 I think It's :banana::banana::banana::banana: ?
I guess it makes sense. If looking for stability, channel A skews should be delayed, so the channel B has some recovery time for the strobe status conditions. On the other hand and opposite if your ram allows and you´re looking for pure OC maybe advancing the channel B skew would make sense.
http://i177.photobucket.com/albums/w...nami/33333.jpg
One more little landmark for me. Together with rampage bios 219 these memories keep on impressing me, and my feeling is it won´t stop here. You can´t get better than this on memories a little over €100 for 2x1GB...
greets
With Dram Static Enabled + Strong is no go?
If yes then Dram Static Enabled + Moderate is possible?
I have tried Dram Enabled + Strong with errors...
Ok, I'll go check with Dram static Enabled.. Noo.. Don't work with Dram Enabled + Strong.. :banana::banana::banana::banana:
Dram Static Enabled + Moderate?
Of course Strong is better but it seems that i always had Static Enable and that is maybe why Strong is no go.
Oh, hey... anyone notice 1004 went to the master FTP?
ftp://ftp.asus.com.tw/pub/ASUS/mb/so...ximus_Formula/
Still no mention on the downloads page, though.
Oh, LOL. Sorry, dude.
I guess I'm not the only one who checks the FTP server first thing after they wake up in the morning!
Someone have E8400 stable at 4Ghz with TEST Blend - stress CPU and RAM ? :confused:
ftp://ftp.asus.com.tw/pub/ASUS/mb/so...rmula-1004.zip
No differences with beta which released since few weeks ?
I have already 1004 but when this Bios was not official...
Nope according a few posts earlier these biosses are identical...
the skew's only effect stability. i was running the highest advance on both skews and finally crashed :D
when running normal no problems. since there was no diff in performacne my experiment is concluded and i am back to skew normal.
Why I can't go over 480 FSB ??? :confused: :confused: I use these settings:
Extreme Tweaker
FSB Frequency : 480
DRAM Frequency: DDR2-1153
CAS# Latency : 5
RAS# Precharge : 5
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
Relax level: 0
CPU Voltage : 1.40000v
North Bridge Voltage : 1.49
DRAM Voltage : 2.20
South Bridge Voltage : 1.125
SB 1.5V Voltage : 1.60
Maby need do some changes in Advaced menu or somewhere else ?
Can anybody reassure me that BIOS 1004 supports the Q9450? And if it does, would the X3350 work then as well?
hey zen from my experience -skew help me to oc my ram higher and +skew worse so i think u may wanan try -skew since u say it doesnt affect performance at all :)
im running 1200 on a 400 strap... which means to oc my ram higher by using a different fsb strap (completely re-ocing my computer for stability) i could not attain as high of a cpu oc as the speed of the ram would be through the roof... leaving it to normal suites me just fine. :yepp:
*edit*
WHY DOES NOBODY HAVE THE SAME L2 CACHE LATENCY AS ME?!?!?
L2 cache latency in Everest test is pure crap in Wolfdale and Yorkfield CPUs compared to Conroe and Kentsfield :(
So someone can help me, with this :banana::banana::banana::banana: ? :confused:
In order to make sure it's not your CPU holding you back from doing 9 x 480, try running 8 x 480 instead. That way your CPU will only be running 3.84ghz and you can test for 480Mhz FSB stability. You might also want to try bumping your FSB and North Bridge voltages a few notches as well.
Once you get 8 x 480 stable then you go try again at 9 x 480. If that fails then you know you will have to bump the vcore volts.
