my tj07 - updated
http://a.imageshack.us/img812/4470/img8593.jpg
http://a.imageshack.us/img291/9015/mcp1.jpg
http://a.imageshack.us/img716/1553/lenz.jpg
http://a.imageshack.us/img844/1550/12601862.jpg
Jacek, try using rubbing alcohol to remove the inscription on the Tygon tubing. It will look so much cleaner without it :). That said, it is already an amazingly awesome rig :D.
First loop finished at last. Not a huge rad i know but will expand as and when :D Still at least it looks nice heh
http://img266.imageshack.us/img266/3914/img0360h.jpg
http://img255.imageshack.us/img255/6328/img0365d.jpg
http://img638.imageshack.us/img638/7296/img0352dz.jpg
http://img210.imageshack.us/img210/4982/img0357t.jpg
http://alexiel.stor.li/LittleDevil/evga1.jpg
http://alexiel.stor.li/LittleDevil/evga2.jpg
though...gonna change pump location :)
White video card looks pimp, Icy. What paint did you use?
Sargatanas,
what's the noise like from that single stage?
I need to move to Germany. You guys get all of the nice "stuff".
Even your worm clamps look better than mine. :clap:
Sargatanas, very happy to see LD's case in real use...:)
hope u enjoy it :up:
The top u used is the Koolance one, correct ? The RX480 would not fit without it ?
not finished but almost :)
http://a.imageshack.us/img814/1461/dscf3345.jpg
http://a.imageshack.us/img265/2158/dscf3343m.jpg
Looks alot more blue in RL.
woops delete
Purple hose don't show up with the camera but I can see them :)
Not done yet still have a few lights to hook up...
http://i66.photobucket.com/albums/h2...s/100_6950.jpg
http://i66.photobucket.com/albums/h2...s/100_6976.jpg
http://i66.photobucket.com/albums/h2...s/100_6969.jpg
http://i66.photobucket.com/albums/h2...s/100_6972.jpg
http://i66.photobucket.com/albums/h2...s/100_6967.jpg
Desk...
http://www.slizone.com/docs/IO/85227...9_05_large.jpg
Where and what kind of green LEDs are you using? EK forgot the single most important feature that their plexi water blocks have holes for, the 5mm LEDs!
Never ending project. Just installed some Corsair Dominators Cas 7 1600mhz ram that was marked $90 below retail thanks to Bestbuy price mistake. So chipped in for the AirFlow Pro Led kit. Real pain to install but looks nice. Nothing like bling. Also updated my Gpus. Not happy about the wattage these guys eat. Thought my 1200 watt psu would last a year before obsolescence set in. Anyhow also installed two San Ace 38mm fans in the front using the Scythe Kama Sutra bay adapter and a pci slot fan controller in the back. I only wish I invested in better fans for my rad...
http://i228.photobucket.com/albums/e...d/DSC00617.jpg
http://i228.photobucket.com/albums/e...d/DSC00619.jpg
davidm, I never knew that case had any potential!
Does tubing are Primochill LRT? it look's really nice, nice build :up:
Cool, but how about some bitspower fittings? it will be great on it!
Congrats!
Wow! We have a monster here :D
Do you have any plans to watercool your graphic cards?
Awesome build! Congrats!
Ok here it is.. up and running :up:
I am new on XS and coming from a hot country like Laos. I need to cool off my PC so i decided to go LC. It's my first time so i would appreciate all comments and suggestions. Thanks!! :D
sorry for the bad pics from 3Gs :p:
rig components:
MIIF/Q9550/Geil Evo One/ENGTX275/SST-ST1000-P+MDPC-X custom sleeve/HAF932
LC parts:
Corsair Pump
EK X-Top Rev.2 Acetal
EK Spin Res Dual Bay
EK Supreme HF Nickle/Plexi
EK Asus NB block
Black Ice GTS120 X-Flow
Black Ice GTS240 X-Flow
Koolance VID-NX275
XSPC UV blue tube ID 1/2 OD 3/4 5ft
Mix of Koolance, Bitspower, Feser, and Enzotech fittings :yepp:
http://i207.photobucket.com/albums/b...C/IMG_1011.jpg
http://i207.photobucket.com/albums/b...C/IMG_1012.jpg
http://i207.photobucket.com/albums/b...C/IMG_1015.jpg
http://i207.photobucket.com/albums/b...C/IMG_1021.jpg
US Forces, I love it! what did you use to illuminate your ek Blocks?
Thanks,
Bought the LEDS ect. from PerformancePC and the resistors from Radio Shack..
Anyhow I made them to length then plugged them into the 3pins on the Motherboard and pointed them up under the block.. I had them in blue which looked nice but went to green since they are Nvidia cards, I have some white and purple LEDS I plan on putting on the CPU and mother board blocks first I have to order the clear top from EK for the CPU as it has the black top right now.
They look a lot better in person then in the photo ;)
This really tough for me right now as I am this >----< close to changing my block to an EK HF Supreme acrylic and adding in a full board block.
well it's quite silent ;)
didn't know that we germans get that much nice stuff ;)
actually I hate worm clamps....but I don't like the plastic ones and without anything isn't safe for me ^^
yea LD did an awesome job with that case, glad that I have mine :)
yep used a koolance shroud (though...will be my last one - fan spacing suxx). the rx480 would fit but atm the case is made for a triple + I wanted the additional space to add some fans :)
