4 Attachment(s)
Dual Loop WC Rig just completed
Just finished my Dual loop rig. Took me awhile because I had to RMA 6 Asus Rampage III Extreme's but I finally got it done. here are the specs. I plan to overclock to beast to death. Let me know what you think of it.
Base System
CUP: Intel I7 930
Memory: Corsair Dominator GT CMTGX3M3A1600C7 6GB Kit
Kingston HyperX KHX Memory Cooler fan
Motherboard: Asus Rampage III Extreme
2 x Powercolor HD 5870 LCS Video Cards (Crossfire)
Case: Corsair 800D Obsidian (Modified)
PSU: Corsair AX1200
Optical Drives: LG LG WH10LS30K Blu-Ray Burner
Samsung DVD Burner
Monitor: Dell UltraSharp U2711
CUP/Chipset Water Loop
CPU Waterblock: EK Waterblocks EK-Supreme HF-Full Nickel
Chipset Waterblock: EK Waterblocks EK-FB RE3
Reservoir: XSPC Acrylic D5 Tank Reservoir for one Laing D5 / MCP655
Pump: MCP655
Radiator: Swiftech MCR320-QP
Flow Meter: Koolance INS-FM17N Coolant Flow Meter wit Frequency Adapter
Fans: 3 x Scythe SP1225FDB12H Kama Flow2 Series 120mm Case Fan
Bitspower shining silver fittings
Koolance BKT-HX001 Radiator Mounting Bracket with Quick-Release
Water Tubing: Tygon R3603 1/2in. ID 3/4in. OD
GPU Water Loop
Reservoir: Bitspower Water Tank Z-Multi 250 - POM/Acetal
Radiator: Feser-X-Changer 360
Pump: Custom Laing D5 - Bitspower Black Sparkle Dress Kit & Top
Flow Meter: Koolance INS-FM17N Coolant Flow Meter with Frequency Adapter
Fans: 3 x Delta AFB 1212L- 2 x Scythe Scythe "SLIP STREAM SLIM" 120 x 12mm Fan - High Speed
Fan Controller: Scythe KM03-BK KAZE MASTER PRO
Bitspower shining silver fittings:):):):)
