His thread:up:
Below is not my photo I don't take any credit for this photo.
His thread:up:
small Update with new Geil Ram and Fan's
http://www.abload.de/img/796pg.jpg
http://www.abload.de/img/81neu.jpg
EDIT: Ace- I've left your pics because they're great, and you've got a nice system, but please note the purpose of the gallery is to show off finished systems, and not just updates :) Worklogs are great for that.
Shape of ram heatspreaders looks just right near HK3. I wonder if it's worth looks-wise to paint cpu wb mounting plate and middle black and copper parts red to make those looks even more similar.
Nice rig Ace :up:
One question, what liqued are you using if you dont mind me asking.
http://picasaweb.google.com/11214923...95392219223762
SORRY I'M RETARDED. I DONT KNOW WHAT I'M DOING WRONG. HOW DO I UPLOAD PICS??
http://picasaweb.google.com/lh/photo...eat=directlink
something for everyone to share...here's my rig and all comments are welcome no matter is good or bad..:welcome:
this is my 1st time using QDC and don't really where to place it,all comments are welcome
http://imgur.com/KIS4y.jpg
http://imgur.com/VtrFA.jpg
Front view
http://imgur.com/08IXB.jpg
side view
http://imgur.com/dUdad.jpg
EDIT by shazza - beautiful system, but please note there is a 4 image limit per case. If you'd like to show more, please edit the post and add links or thumbnails. Thanks!
:p::p::p:....sorry for the namecard..im taking part for the modding competition organize by our local modders here in Singapore so we need name,nickname and date written down while taking the photo of our rig
Lol,apologies for that shazza, but thanx for editing it fort me....
The Platinum Box Rig is complete.
Project envisioned in 2009, finally complete in 2010.
[Components]
Processor: Intel i7 920 @ 3.4Ghz
Motherboard: EVGA x58 SLi
Ram: OCZ 6Gb 1333mhz DDR3 Tri-Channel
Harddrives: 2x 2TB WD Green, 1x 1TB WD Green
Graphics: Nvidia GTX280 1Gb
Chassis: Lian-Li A05N Silver
[Cooling]
CPU: Watercool.de HEATKILLER3.0
NB: Koolance x58 Northbridge waterblock
RAM: OCZ Silver heatspreaders
GPU: EK Fullcover GTX280 Nickel-plated waterblock
Radiator: Swiftech MCR360 Radiator
Pump: Swiftech MCP355 18watt with XSPC top
Fans: 3x Evercool Aluminum Fans, 1x Enermax Apollish
Fan Controller: Scythe Kazemaster ACE Silver
Tubing: Tygon Lab-grade R3603 3/8" tubing
Fittings: Bitspower fittings and attachments
Enjoy~
http://img.photobucket.com/albums/v4...inumBox010.jpg
http://img.photobucket.com/albums/v4...inumBox015.jpg
http://img.photobucket.com/albums/v4...inumBox006.jpg
http://img.photobucket.com/albums/v4...inumBox003.jpg
Sorry for the bad pics. I'll update with better ones later.
http://i83.photobucket.com/albums/j2...6/101_0557.jpg
http://i83.photobucket.com/albums/j2...6/101_0546.jpg
http://i83.photobucket.com/albums/j2...6/101_0549.jpg
Here are some photos of my upgrade/redo (the first major since 2007). The project is named for a famous text written by Danial Bernoulli about the mathematics and engineering of water flow (hence the name Hydrodynamica). The 'DS' stands for dead silence and the '3X' means that the build has three separate water loops (one for the cpu, one for the gpus, and one for the chipset, .. although, in this current configuration, the third pump is off and the XSPC RX 120 that would be used for chipset cooling is currently helping out on the ATI 5870s). The project produces 18 dB at almost exactly 30 cm and from three feet away is truly dead silent. It also features some custom work, including a special negative pressure airflow system with custom backplates to radiate heat, a rebuilt PhysX card with a custom circuit board add-on and passive cooling, a custom built handle on the XSPC dual DDC reservoir for pulling it out to add coolant, etc..... All three water loops and cooling are internal. Notice that I did not use a SLI bridge for the water blocks on the two GPUs, as this cuts flow and increases temps. It is not as decked out as some of the mega rigs I have seen here at XS, but then it is also not a show piece either. It is a day in and day out rig where I cannot stop operations just because Bitspower came out with a new color combo.
The temps are:
When flight simming or gaming; cpu ~41 deg C, gpus 44 deg C, northbridge 39 deg C, PhysX card 34 deg C
When running Matlab, finite element analysis or simulating neural networks; cpu 43 deg C, gpus 46 deg C
When running Prime95 on 12 cores (at the one hour mark); cpu is roughly 63 deg C
The current specs are:
i7 980X @ 4.4 GHz, ASUS P6T Deluxe Version 2, 12 GB Corsair Dominator @ 1866, 2 x 5870 (Crossfire), Ageia PhysX PPU card, Creative X-Fi Titanium Fatalt1y Pro, 2 x OCZ Vertex 120 GB in RAID 0 (Firmware 1.6), 2 x OCZ Vertex 2 120 GB in RAID 0 (Firmware 1.11), Seagate 1 TB, Thermaltake Toughpower 1200W modular, Lite-On 24x DVD burner and Pioneer BDR-205 Blue Ray Burner, Apogee XT on the cpu, MCW-80s on the GPUs, DDC 3.25 pumps, XSPC rads and XSPC dual DDC reservoir, Lamptron FC2 version 2, Scythe S-Flex and Yate Loon low speed fans, Logitech G510 keyboard, MX Revolution and Razer Mamba, Creative Gigaworks 750, Sharp LC-46D85U, Track IR 5 and CH Fighterstick/ Pro Franken Potato Throttle/ Pro Pedals
(some of the wiring and the speaker cables are run behind the walls for less clutter)
Your build looks great, dude :up:
My next case probably it will be TJ07, AWESOME!
I know you're new, so let me show you the rules of this thread :).
Four Simple Rules:
1) No larger than 1280 x 1024 pixel (but 1024 x 768 pixel is preferred),
2) The limit on the number of pictures is 4 per case (if you want to post more than 4 pictures, use thumbnails or post links without using the IMG tags),
3) Do not quote images,
4) Finished cases only, no worklogs.
Optionally, it would be nice if you could list your water cooling components.
Was gonna say the same thing, please dont quote pics hehe, welcome!
beautiful rigs here, guys :up: thanks for the pics
here is my first attempt at LC. just finished the build and will run it tomorrow. hope it runs! ^^ :D
p.s.sorry for the bad pics. :hrhr:
http://picpost.overclockzone.com/?di=1112834590456
http://picpost.overclockzone.com/?di=2128345914616
http://picpost.overclockzone.com/?di=6128345914615
http://picpost.overclockzone.com/?di=0128345919110
wow wow very nice
^?555+
sweet rigs
Recently updated my rig, sorry about the poor quality pictures.
http://i946.photobucket.com/albums/a...t/pccase01.jpg
http://i946.photobucket.com/albums/a...t/pccase03.jpg
http://i946.photobucket.com/albums/a...t/pacase02.jpg
http://i946.photobucket.com/albums/a...t/pccase04.jpg
may need to try the edit button again with those large pictures..
Lots of nice clean rigs here lately. And, thanks, Trader88, for resizing your photos.
