Wow you serious? Can anyone verify this? Maybe you werent stable at 1.4v and you just didn't know it. Give us more information. Right now I'm running fine with settings from 0804.Quote:
Why would you remove your overclocking settings if it's completely stable?Quote:
Originally Posted by jVIDIA
0910 wasn't working fine for me. So i reflashed, then restored bios defaults and then turned the pc off the power for a few secondes....then turned it back on.
now it's perfect.
Could be that in BIOS that you need to re-set the IDE config back to RAID, happened with me. But the RAID itself is not lost. After the BOIS-upgrade, I get "OC checksum failure" and all settings are back to default. That's why you'll need to reconfigure all BIOS settings - annoying but no loss of RAID (or data).Quote:
Originally Posted by blackspawn
R.
Is not the video setting or driver problem.Quote:
Originally Posted by dinos22
The SAME problem happens on two P5B deluxe wf.
The first one goes to RMA and also dosnt have TV-Out.
When i sended the mobo to RMA, iv get back to my old system(MSI 915G + P4 520) and it works fine there.
With the new P5B received from RMA the same problem happens. No TV-Out with the same driver. Already tryed another drivers and nothing...
Thanks for the reply :), i know there is right in the middle of the new bios release.
Ill check when i get home, thanks.Quote:
Originally Posted by Ancient1
Iv found this(Interesting):
PCI-E 1x Link Width issue :
"Happens when OC-ed. After restart link width is automaticlly set to 1x instead of 16x, which causes significant performace downgrade. Reason unknown. Happens mostly with ATI GPU cards. Possibly a BIOS protection measure, preventing percieved possible damage to GPU or motherboard, or a BIOS problem with proper video card initaition."
Originally Posted by eyes.only
hmm, did some interesting discoveries today:
everest:
idle:
cpu:42
core 1:41
core 2:43
load:
cpu:86
core 1:66
core 2:65
asus ai suite:86
Even on idle, it stays at about 79degrees:slapass:
What could be the problem?
Using a soniq tower here:mad:
Edit again:
I've put the cpu on default with default clocks and volts:
everest:
idle:
cpu:34
core 1:34
core 2:36
load:
cpu:47
core 1:47
core 2:47
What could this be, please help
if you are seeing 26% cpu usage on your friend's quad core cpu and you see 90% cpu usage on your dual core for the same nero action then i would think that the Nero load is being distributed equally across all four cores!...less cpu usage doing a task is a good thing so it will allow the user to do more multi-tasking while handling the Nero record...
Have you got PECI enabled in bios?
If so try disabling it, it is known to screw up temp reading.
I cant make mine work with usb stick even if i turn floppy emulation mode on.Quote:
I used EZFlash with a USB stick
Can u give me details of how u do it. e.g. must it be named in certain way or in certain directory?
Isint any of u using AHCI ? Plz tell me what is exact name of Intel controller in devmgmt.
http://img180.imageshack.us/img180/2...idrivervc1.jpg
Which one is in your devmgmt?
Is was already disabled, but thanks anyway.Quote:
Originally Posted by peron
Changed my settings from default to 2800mhz (multiplier to 7 instead of 8)
1,45 volt E6400@3200mhz
everest:
idle:
cpu:42
core 1:41
core 2:43
load:
cpu:86
core 1:66
core 2:65
stock volt (1,288 bios) E6400@2133mhzeverest:
idle:
cpu:34
core 1:34
core 2:36
load:
cpu:47
core 1:47
core 2:47
1,35 volt E6400@2800mhz
idle:
cpu:40
core 1:40
core 2:42
load:
cpu:55
core 1:56
core 2:57
Load testing was done with TAT.
what is your voltage when you oc?Quote:
Happening over here too. Problem confirmed. Looks like 0910 requires more voltage to be stable. I couldn't even pass orthos for couple minutes with 0910, but with 0804 everything is stable. Same exact settings.Quote:
The 910 BIOS seems to have fixed the double boot issue... for me at least.
I didn't even have double boot issue with 0804. I think my configuration doesn't require the bootstrap to be changed.Quote:
Originally Posted by Eluzion
look at my post before yours:toast:Quote:
Originally Posted by idiotekniQues
For me 0910 is working fine. No overclocking problems, no need for much voltage.
3010@1.25v
What do you guys think about the OCZ Platinum XTC DDR-800 to be match with the P5B Deluxe and E6400? Is any other bran/speed memory with a good price performance that you would recommend??
Tks,
4. It is needed to load RAID drivers for SATA discs, during windows install even if RAID systems will not be utilizied, or a single disc is used, to be able to use full benefits of AHCI. This can be done in 3 ways :Quote:
Originally Posted by Angelico_Payne
a) By pressing F6, during install, and supplying drivers via floppy disc
b) By slipstreaming the drivers into a Windows installation disc, prior to installation.
c) If you have allready setup your instalation of Windows without using the first 2 methods. Instead of reinstalling the system, go to device manager and update the ide controller that's connected to SATA drive. Make sure you force it to select “Intel® 82801FR SATA AHCI Controller”. Restart, and go into BIOS before Windows starts and change 'RAID/ATA' option to 'RAID/AHCI'. Boot into Wndows.
This is for non raid users!
i have the PCIe issue even i use an NVidia card....
Well, iv found my problem...ME!
Yep, i'm a real noob and did the very same mistake on 2 P5B.
I didnt use the screw to hold down the Vga, so.
Iv played BF2 and CSS with no problems, just the tv-out... wtf.
Romano, ... so?
Askimo, what is a good price for you?
Check(here on the forum) the on-line deals and etc...
the issue is not only for Ati card...
This was found out earlier:Quote:
Originally Posted by gmcinema
That Friggin HassleMax again !!!
Thought I've gotten rid of background noise by disconnecting PC_Speaker connector.. and I did . BUT , when I record myself , with the (SuperBeam mic, using Windows Recorder) , there's this innervating , undulating background sound.
I held the mic in my hand to make sure no vibrations reach it. and its supposed to CANCEL Background noise !!!
I dunno if you've found the gremlin running Orthos .... I've found that :Quote:
small ffts - tests CPU OC
Large ffts - tests Ram OC
Blend- tests both CPU and Ram.
I've run ex. 5hrs stable with "small ffts" but will error with "Large ffts" within 5mins. so I know that my ram needs tweaking for that clock speed.
P5BD e6400@3.6ghz 1.48v Orthos blend 48hrs! :)
http://server3.uploadit.org/files/vp...D.C2D.3600.jpg
OMG Thank you, i allready gave up. Asus support was not responding either, which was no suprise :D :woot: :clap:Quote:
Yes, but mostly happens with ATI cards. Or perhaps we can put it this way : most of ppl reporting problem, are using ATI based GPUs. :fact:Quote:
