"CM ATCS 840 Blue Blood" is having one of the best looking blue sleeving i have ever seen. Looks supper cool.
mav2000, i think you should use these in your new build.
OBSIDIAN RED
http://i627.photobucket.com/albums/t...4/IMG_0319.jpg
http://i627.photobucket.com/albums/t...4/IMG_0337.jpg
http://i627.photobucket.com/albums/t...4/IMG_0333.jpg
http://i627.photobucket.com/albums/t...4/IMG_0329.jpg
System Specs:
» spec » intel corei7 920,memory gskill 6GB,vga nvidia gtx480,psu thermaltake 750watt
Performed Mods:
2 loop: loop 1 : -EK WB procie HF Gold -radiator feser 480 -resevoir bay xspc -2 pump mcp355 +top double Xspc -tube red feser -cooland feser red -fetting comprestion -fan enermax red loop 2 : -WB EK nickel plexi gtx480 -radiator 12x2 black ice -1 pump mcp355+top bitspower -resevoir EK 250 basic -tube red feser -2 fan cooler master red
^^I agree, that is a very nice looking setup. The only improvement that I can think of is if the cables were individually sleeved....then it would be perfect IMO. :D
Another improvement: getting better rad fans... CM R4s aren't the best with static pressure.
Here's the Black Widow :D
EVGA 4-way Classified WC'd, i7 980x w/EK HF, 6GB Dominator GT 2000MHz, EVGA GTX480 x4 w/EK-FC WB's, OCZ Vertex 2 120GB, WD CB 1TB, LG Bluray writer, Silverstone Strider1500, HAF X.
OH.
MY.
GOD.
...will it run Cry... oh nvm.
^^ that is one awesome setup you have there kruzn4evr. I hope that mine turns out as nice looking as yours does.
kruzn4evr, that's something to look at :up:
kruzn4evr that black widow looks as deadly as the specs.......Awesome!!!
@kruzn4evr what kind of SLI water block connectors are those?
kruzn4evr your hardware is undoubtedly godly and you definitely took alot of time with the cabling/tubing but for fracks sake please put it in a worthier case!!! That HAF X and teetering radiator bracket are eyesores. That type of hardware belongs in a 800D, TJ07 or a custom enclosure.
4x 480s jeebus, Hows your temps ?
No way. These http://www.auzentech.com/site/products/case.php are MUCH uglier than an 800D, the 800D is too bland to be ugly :D
800D is stylish with clean classic lines, not bland. And heaps better then many plastic overdesigned cases which frankly look cheap in comparison. You don't need carbon fiber wing, full body kit and stickers for rolls royce, you buy expensive wine to put in trunk :)
Thanks for the comments guys, first off, the 800D and TJ07 wouldn't work (maybe with some serious modding), I choose the HAF X simply because it was the best case of choice that has 9 expansion slots that holds the 4-way Classy board, I almost went with a MM but between price and sheer size (I wanted something not so huge) the HAF was really the only choice. As for the "teetering" rad bracket, its as solid as a rock and really the only way to go for a rear mounted quad rad.
The SLI connectors are Bitspower C-07 D-Plugs which again were IMO the best part for the job and look quite nice to boot. Temps for the cards are pretty good, all 4 are approx. 32-34c idle and hit around 62c with Furmark, real life temps while gaming etc. they never go over 53-54c, I'm looking at adding a triple rad on top in the next few days when I can get the time. They scored pretty nice on Vantage too ;) http://www.evga.com/modsrigs/TopRating.aspx
You need to put more money into that build [/Sarcasm]
Look here:up:
The craftsmanship is pristine and it comes pre painted/coated. I have one waiting in a box for my case to be finished at the powder coaters.
^^ can you post a pic of what you are linking to....I can't get into that area of the site.
