Originally Posted by
TheOriginalTB
Ok time for some of my findings with this mod (BIOS 0219).
Logitech mouse in the outmost USB port nearest the LAN - the BIOS hangs at USBINIT - moving the mouse to another USB port and it boots perfectly.
FSB 452 gives 448MHz, 551 gives 551, and 553 553MHz
Multiplier reverts back to std. when loading an OC profile, making the board unable to boot. Must select the correct lower multiplier after loading the OC Profile. This is only an issue when running lower multiplier than default.
NB temps are reported lower, doubt it's because the NB actually runs cooler..
CPU temps seems to be reported more realistic than on the 0907 MF BIOS - which gave me silly low temps. (like 9 deg at boot)
The board still overvolts like crazy on FSBTT, NB, RAM, and others.
Performance:
This BIOS IS slightly faster than the latest MF bios. With the same settings both read, copy and write were higher, but not by much - the latency however is about 1ns better.
Overclocking:
I have not been able to overclock more than with the MF BIOS, but this is probably due to my cpu more than the board.
With the MF bios I was able to run 500MHz FSB, with the RF bios I'm not even able to boot at 480MHz - major drawback..
Now I'm able to use all memory dividers - with the MF there were some dividers that wouldn't boot at all.
Software:
Windows do not need a reinstall - however Everest no longer detects NB voltage, SB voltage and vcore is reported wrong. (1.1 when actual 1.50)
But all in all - I think this will be a very good board with more matured RF BIOS's.
