Acheiving stability at 3600
Guys, I need some advice. I had my chip stable at 3440 (430*8) 24/7 prime, small ftt and blend OCCT cpu and ram rock stable at following settings:
430*8
vcore 1.3375/1.30,
LLC enbl,
NB 1.49,
FSb 1.40,
DRAM 860 1:1,
DRAM 5-5-5-18,
DRAM volts 2.0v,
DRAM static read enable,
transaction booster disable, relax level 1.
most every thing else auto.
I changed recently to
3600
450*8
vcore 1.38125/1.34,
LLC enbl,
NB 1.51,
FSb 1.40,
DRAM 900 1:1,
DRAM 5-5-5-18,
DRAM volts 2.0v,
most every thing else auto. temps 70,69,68,68 load
OCCT mix is stable (6 hours,)
OCCT RAM stable (2 hours)
OCCT CPU stable (2 hours)
Prime 95 small ftt stable (8 hrs)
Prime 95 Blend crashes at 45 min to 3 hours
Photoshop did a BSOD out of nowhere
MEMTEST stable 4 passes at current settings
I need to be stable for 24/7 use. I do not know where do I go from here? :confused: Increase vcore, fsb, DRAM, NB or all ? Rather than try and experiment forever, I thought Ild ask the experts.
Ideas and recomendations greatly appreciated.
