additional angle:
additional angle:
red scorpion?
I wish I knew about the Achilles S1284 though, I would get that over the S1283
thanks for the review btw, I feel vindicated with my purchase. :rofl: I did replace the push pin with a Thermalright bolt in kit.:up:
I might switch fan though with my ZALMAN ZM-F3RL 120mm Red LED since its more of an actual "Red" vs the orange stock fan it came with...more bling than performance.
So, you think I got room for that HR-11 on this setup?
it all depends on where the back of the GPU is positioned on that card, and whether the backside cooler will make it far enough in either direction to avoid problems with hitting the heatsink or the ram. ;)
The HR-11 comes out above the middle point of the 2 SLi connectors..check out Tommy's pics...I say you are good to go.
Will fit without problems :)
@Cpl Ledanek: yup the HR-11 is gonna fit...as long as you don't put another fan (for a push/pull config) on your CPU heatsink.
Here's my 24/7 setup.
E4300 @ 3.2ghz (Noctua NH-U12F + 120mm Nexus @5v)
OCZ Platinum XTC rev.2 PC2-6400 2X1GB (TT Spirit RS)
Asus P5N-E SLI (TR HR-05 SLI + 80mm @ 5v, Enzotech CNB-S1L)
EVGA 8800gts 320mb (TR HR-03 PLUS + 120mm Yate Loon @ 5v)
Samsung 1tb F1 HD103UJ (140mm Xion @ 5v)
Corsair HX520 (120mm Yate Loon @ 7v)
X-FI Music
http://img402.imageshack.us/img402/9489/1mediumer3.jpg
http://img254.imageshack.us/img254/1153/2mediumtx1.jpg
http://img254.imageshack.us/img254/6716/3mediumvn2.jpg
http://img403.imageshack.us/img403/5881/4mediumph2.jpg
I also ordered the HR-11.... I actually don't think it'll fit, but I guess I'll find out in a couple days :hitself:
@_Prospect_: hope this will help...how far the HR-11 goes to the back of the HSF
http://i116.photobucket.com/albums/o...TP35-T2R29.png
wow enzotech ramsinks !
Thanks for the pic emoners. :up:
I should have been more clearer. I was actually referring to the space between the backside of my video card and my hr-05 sli.... very little room there :confused:
btw, love your setup :cool:
Do you run everything passive like that? what kind of temps do you get?
wow great pictures people :D
great pics emoners, manyga, and _Prospect_
my newest build. still not done yet though. still need to install my S-Clip so that I can rotate my Ultima 90. Also need to finish up the cabling(LED wires and a video card fan among others). Plan on adding a thermalright HR05 to north and southbride(could most likely use an HR05Sli on the chipset near the bottom of the board) as long as i have enough space.
http://i2.photobucket.com/albums/y43...x/DSC01487.jpg
theToX, don't you think you want to remove the AMD sticker on the motherboard? hehe
havent really thought about that actually lol. i probably will though.
also going to paint the inside black at some point.
rarely seen someone use the V2 looks awesome theToX.
thanks. its still a work in progress. I found some really good deals on an 8800gt and an 8800gts so im debating making my credit card hate me some more.
Get an 8800GTS :rolleyes: :p:
im probably going to hold off for a little bit. my car is due for brake pads. pads and the stainless steel lines i want are going to come to almost 600 so the video card will have to wait. :(
Ahh okay, well, maybe by then you'll find a better deal on a new GPU
I love seeing inside cases, i most appreciate guys who keep things clean....dust bunnies and cabling/layout etc.
