the one most prefered....
ive never heard of a bad ek product...
what i dont understand about the back plates of full cover waterblocks... WHY ARE THEY SHINY?!?!?
i dare anybody to argue with me, but just painting it black will reduce temps as black radiates heat better than any other color. more heat radiated, less heat on the component. why do you think radiators are black? :p:
i can show you thermal images proving this point.
if it didnt void my warranty, i would have painted all the heat pipes and "fin pin" hoopla to black.
(yes i know modding to rampage voided my warranty, but how would anybody know if i just flash it back?)
Man, am I in the WaterCooling thread? This is starting to suck.... Not because WC'ing sux, but because this is not what the original thread was about. This is now about smoke and mirrors? PMs
Yeah, hop in the LC forum if you want to find answers about watercooling questions ;)
Easy peeps I just ask'd a question :sofa:
Didnt know it would create problems, thanks for the info tho guys :D
I just flashed my PE5 to the Rampage 0219 and it works!!!
Thank everybody at this thread
idk, it might be more than that. I fried 2 sets of the new revision on my board and the old Ballistix I had were just fine. My voltage never went over 2.1v
I think there is something with the new Ballistix revisions that lets this board kill them at even modest voltage.
hey Grn?
today i ordered the Corsair Dominator 8500's :yepp:
hell yeah. (thx for advice)
I can't seem to get anything stable past 425 FSB. It's stable in OCCT for at least 2.5 hours, but if I raise the FSB to 435, it becomes unstable and more volts don't help. Here are my current BIOS settings for my e8400:
BIOS 1004
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 425
PCI-E Frequency: 100
DRAM Frequency: DDR2-1021
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 5
RAS# to CAS# Delay : 5
RAS# Precharge : 5
RAS# ActivateTime : 15
RAS# to RAS# Delay : Auto
Row Refresh Cycle Time : Auto
Write Recovery Time : Auto
Read to Precharge Time : Auto
Read to Write Delay (S/D) : Auto
Write to Read Delay (S) : Auto
Write to Read Delay (D) : Auto
Read to Read Delay (S) : Auto
Read to Read Delay (D) : Auto
Write to Write Delay (S) : Auto
Write to Write Delay (D) : Auto
Ai Clock Twister : Strong
Transaction Booster : Disabled
Relax level: 0
CPU Voltage : 1.3375
CPU PLL Voltage : AUTO
North Bridge Voltage : 1.49
DRAM Voltage : 2.10
FSB Termination Voltage : 1.40
South Bridge Voltage : 1.050
CPU GTL Reference : 0.63X
North Bridge GTL Reference : 0.67X
DDR2 Channel A REF Voltage : DDR2-REF
DDR2 Channel B REF Voltage : DDR2-REF
DDR2 Controller REF Voltage : DDR2-REF
SB 1.5V Voltage : Auto
What should I set the cpu ppl voltage as?
I'm guessing cpu pll = SB2 in pcprobe2.
If so, it's 1.52
Ok time for some of my findings with this mod (BIOS 0219).
Logitech mouse in the outmost USB port nearest the LAN - the BIOS hangs at USBINIT - moving the mouse to another USB port and it boots perfectly.
FSB 452 gives 448MHz, 551 gives 551, and 553 553MHz
Multiplier reverts back to std. when loading an OC profile, making the board unable to boot. Must select the correct lower multiplier after loading the OC Profile. This is only an issue when running lower multiplier than default.
NB temps are reported lower, doubt it's because the NB actually runs cooler..
CPU temps seems to be reported more realistic than on the 0907 MF BIOS - which gave me silly low temps. (like 9 deg at boot)
The board still overvolts like crazy on FSBTT, NB, RAM, and others.
Performance:
This BIOS IS slightly faster than the latest MF bios. With the same settings both read, copy and write were higher, but not by much - the latency however is about 1ns better.
Overclocking:
I have not been able to overclock more than with the MF BIOS, but this is probably due to my cpu more than the board.
With the MF bios I was able to run 500MHz FSB, with the RF bios I'm not even able to boot at 480MHz - major drawback..
Now I'm able to use all memory dividers - with the MF there were some dividers that wouldn't boot at all.
Software:
Windows do not need a reinstall - however Everest no longer detects NB voltage, SB voltage and vcore is reported wrong. (1.1 when actual 1.50)
But all in all - I think this will be a very good board with more matured RF BIOS's.
W00t! P5E just flashed successfully. Good work guys. I'll report my overclocking finds later.
Hey guys I've been away sorting GFX and lost track of this thread. What's considered the best BIOS for OC'ing now and can someone give me a hand OC'ing my E6750? Tried Renegade's original options fromt he start page my but my PC no likey. :(
I have had it up at 3.8Ghz but I'd like to try for 4Ghz if possible, if not then more stable settings for 3.8GHz (was just playing around with settings before - now my LC is here I hope I can get it set up nice n proper!)
~Bex
