Works with 1,24 vtt too. 1,45 was on auto.
Where to go from here?
http://img186.imageshack.us/img186/4817/67260282jz3.jpg
Q6600 G0 @ 3.6 GHZ
Corsaid Dominator 1066 5-5-5-15
evga 8800GT 512
Asus P5KE
vocre 1.312
BIOS Settings:
PLL = 1.7
FSB Termination voltage = 1.3
DRAM = 2.3
NB = 1.55
SB = 1.20
Clock Over-CHarging Voltage: Enabled
Load Line Callibration: Enabled
CPU GTL V Ref = 0.61x
NB GTL V Ref = 0.61x
CPU Spread Spectrum: Disabled
PCI-E Spread Spectrum: Disabled
fiveprime, what strap are you using ?
Im running a 3:4 fsb dram ratio, I set the memory speed manually and had the strap auto adjust.
Has any of you guys had trouble overclocking your q6600 on a 790i ? I cant get over 3ghz and vcore drops heaps between bios and windows while not being consistant either . Im not sure if I should get a q6600 friendly mobo or get a 45nm cpu . I do have a qx9650 on the way but it will be a week or so before it arrives.
:shrug:
BX80562Q6600SLACR -is this any good? Shall I go for it?!
l805 probably is 1.325
strumf666's L808 is 1.225v, so try to find one of those...
I'll trade someone my 1.325 vid + 50$ for a 1.225- vid :P
(is 200-300mhz worth 50$ hmmmmm)
This is my first post here , great forum :clap:
I've tried 2 Q6600s , one is L747 in the older grey box and one L750 with the newer blue box .
Both have 1.325 VID and both would only reach 3.2 with Vcore set to 1.375 in bios
Tomorrow I will recieve a new L804 one and keep my fingers crossed for a lower VID and/or higher overclockability although it seems that L804 is as bad
I will keep you posted
Did I get a good chip or are my results typrical for G0s?
Looking at your results and volts you got a pretty good 24/7 settings there. I would say your chip is nice too because your vcore is below average for that speed. :up:
Too bad I sold my L737B a while back :/
@fiveprime :
Your 3DMark06 score seems low to me @3.6 because I got 15030 with my Q6600@3.2 !
I still love these Q6600 L737B's
Mine's vid 1,225 and for 24/7 3800 with 1,4375 vcore on bios, 1,41 drop on water...
My Max Bench is 4260 with 1,6250 vcore on bios and i got a 11,806 spi 1MB
Still don't find a reason to change CPU
I love Q6600 L737B's :D
And thanks for my mate WizardOfOz that sold it to me :clap:
Cheers
Sergio
Just recieved the L804 , its VID is 1.2875 , is that good ?
Great for a L804, mine is 1.325
My Q6600 is stable at 3.6 and has a VID of 1.325. Look at sig for specs.
