so this means his cap is CPU not memory. ROFLMAO
Looks like a 9/10 divider to me so he's at 243, not bad for inexpensive sticks.Quote:
Originally Posted by MonkSP
Its not good for benching but he's into Gaming and Photoshop so its more than worth the trade off bandwidth for more memory available for applications.Quote:
Originally Posted by TEDY
2.7ghz for a 3000+ is actually pretty nice. I wonder how many people can run their Winnies up to 2.7ghz while sporting 2Gb memory? Maybe his OC is not super xtreme but his happiness is. :)Quote:
That is very good for a Winchester or for most any AMD processor. Looks good :toast:
jjcom
this is my ocz VX value...260fsb at 3.6vdimm...
Originally Posted by Rabbi_NZ
Hi. In your sig "1T-2-2-2-8-7-15", can I ask what is 1T for?
In an Anand Tech article, they refer to "2-2-2-6 3.3V 1T" as well, which made me want to know if it's the same "1T".
Thanks a lot. :)
1T and 2T. 1T is a higher preformance mode. Think tighter latencies, which is a good thing. Less time needed to get info from RAM to point B or from point B to RAM. Higher bandwidth, etc :)
jjcom
here r my results
http://www.xtremesystems.org/forums/...9&postcount=13
Thanks. Where can I find this option in my bios in order to set it at 1T or what is it called?Quote:
Originally Posted by jjcom
Thx a lot.
it's called CPC
What does CPC stand for? Thanks.Quote:
Originally Posted by babyelf
command per clock.
Thanks a lot. :)
This babes are doing 2-2-2-6 @ 255 with 3.5V. They reach 260 htt when I lower the multi of my winie to 7. Guess I am beeing limited by the winnie!
Time to rehash this thread again...
I'm currently using OCZ's Value RAM. I can't get it stable over 220MHz probably because my mobo won't let me give it more than 3v, so I'm using a divider that has my memory running at 212MHz with 2,2,2,5 1T.
I want to add 2x1024 to my system. Can I mix in a different brand of memory with my current OCZ? I'm looking for what would be most compatible with OCZ4001024WV3DC-K.
Since I'm not going to be able to OC my memory much, I'm not looking for the best memory, but something that will be stable along side my OCZ running at 212MHz 2,2,2,5 1T.
Well, it's my understanding with 4 sticks, 1T isn't possible???
