Yes tim, It is one of the sure things to add in future versions.
can anyone tell me a way to run a system with a freeze pack in it without the computer so i can do so load testing can i just hook up a computer start botton to it and run it like that
You need to connect a psu to the controller's molex.
To start the psu you need to connect its (green if I remember correct) wire with a black one.
Basically the controller needs to "see" a voltage of 5V on its molex plug so that it thinks the pc is on, and the controller itself stays on. The voltage value is not so critical anything bettween 4-12V will do the job. For example you could use a battery pack.
DO NO FORGET, POLARITY (+ -) OF THE VOLTAGE MATTERS!!
Double check before you do anything. Ask if you are not sure about something.
Regards!
Some more Freezepack Controllers are ready to ship ;) And some of them are already shipped! Thanks for the trust!
http://xs124.xs.to/xs124/08055/pic0001522.jpg
Thanks to you and Gsmaster for making good products, and giving a proper help/support to all customers;)
I'm sorry it probably says somewhere in this thread already, but how many temperature sensors does this read and to what temperature?
it's just one probe, and it reads down to -50 for sure (i've tried). I also remember that someone had this controller on a ~-60*c range rotary unit and the controller didn't show below -54*C.. think it was piotres.
usps is an american postal company, not located in greece, and last time i talked to unseen he was moving to ireland.
send him a pm or gsmaster, ups/fedex or something should be possible to use.
unseen these the same version as the old ones, or we got updates to these babies?
kayl: i got one out of this batch and it's the same version a I assume. It's a tad different color of the components (relays) but otherwise, the menus, functions, dimensions, software is the same.
Hello people!
There are minor changes on some parts of the controller (relays,terminals, capacitors...etc),depending on the availiability of these parts, but the design is the same.
As regards shipping, I usually ship with the local post, and the package requires a signature on delivery. The package should arrive at the local post office.
regards
john
Hey guys, got a quick question about my freeze pack. I have been using it for a while now on my test build. The other day I turned off all power by switch off the surge protector as I was leaving for the weekend. when I came back and turned it back it it now reports wrong temps, like way off. Sitting on the porcessor at ambient temp (like 20c or so) it says its over 50c... anyway I can do a reset?
Thanks! I love the contollers!
Hello
What do you use for the controller's power supply? Possibly a high voltage spike at the mains power, has passed your power supply and damaged the controller.
Hey gsmaster. I am using a small dc power adapter like the one here: http://http://cgi.ebay.com/12V-5V-DC...QQcmdZViewItem then have a molex connector and using the 12v of that to the controller.
how can i get one of these controllers
Hello
That can be hard now ...
From what I know :
Unseen stopped all works connected with phase-change .
GSMaster is in army . Try to PM him, there is an e-mail adress in his signature.
Good luck ;).
Best Regards
Peter
does anyone do controllers as well
i think duniek is starting to...
Hi,
I have 3 left. If anybody wants can pm me.
hehe you should do an auction on those!
