Buhahaha 4.1GHz @ spi32M :|
you are really SICK (your cpu too :D )
Originally Posted by MaSell
Just wait till I figure out how will I provide over 1.9VCore to this mobo and you'll se OVER 4250MHz Super-Pi 1M and ~4200MHz 32M......:)
bahaha the unstoppable hipro!
:D I've already benched Super-Pi 1M @ 4180MHz...... ;)Quote:
Originally Posted by vapb400
Originally Posted by Willis
Yes.....EXACTLY 1.91VCore....
Thank you very much my friend.......:) :toast:Quote:
Originally Posted by Pedro Rocha
Hipro, what do you think about ~2.2v at dothan? :cool:
I've tested it up to 1.97VCore on P4GD1 mobo and it's doing OK.....;)Quote:
@ 1.85 i can bench spi 1mo @ 3433 max
with 1.90 i can bench spi 1 mo @ 3469
but the max screen didnt change :p 3488
afraid increasing the vcore up around 1.95 1.97 on pm740
your 1.97 is under ln² or cascade ?
YGPM
Under LN2....Quote:
Originally Posted by skirms_fr
Will you marry me?
lol, JK. Nice work :)
lol this is frkn unbelivable. Unreal cpu speed Hipro:slapass:
Big grats form NY:toast:
congratulation!hipro :toast:
Also exceed the wall of 4400 at this tune.
Do I also pursue, if time is made?
still love youre work... what an awesome benches you have there.. and 1.97v :D WTF
Thank you guys.....:)
I came up with a conlusion last night as for the X1900XTX.....I gained about 40MHz more on Rams out of it(the same vga)......I have also tested another two of them till now but none of them could reach 776MHz core on air as is(default heatsink) as this one does, so as to put them under cascade and test them for cold bug.....
I did some mods on P4C800 mobo so as to trick it and give me more than 1.91VCore without rebooting but no go yet....I'll try to figure out what is stoping VCore and acts like this........It's realy a pain in the arss when your CPU wants more "food" and you ain't have enough to feed it......:(
I also "squeezed" it a bit without many tweaks and benched up here.....MORE to come for sure.....;)
http://www.thelab.gr/images/Hipro5/D...18.297_png.png
nice hipro, are you ever going to do that aquamark run @ 4+ghz? :D
I did some testings last week, but when it reaches to it's end for showing the result, it crashes somehow......It's not the VGA(I have tested it and default), it's not the CPU or the rams(I have tested them on a lot lower frequency).......Something has to be with Aquamark.......I reinstalled it but same happens......I remember though that with the 7800GTX 512MB, I didn't encode such problems for the 143xxx score below 4GHz......:(Quote:
Originally Posted by ex2cib
there is a patch for pci-e cards for auquamark3... you need it or you will crash at the massive overdraw test.
If you guys know where the patch is, I need it too...
Heres patch for AM3.....http://www.overclock.net/664693-post6.html
Amazing scores Hipro!!!:slobber:
No other to say...
:worship: :worship: :slobber: :slobber: :slobber:Quote:
Originally Posted by hipro5
Why can't my rig have that problem lol :brick:
No cold boot problem any more as for the P4C800E-D......I think that feeding the DOTHAN with 1.9VCore, solved that......It now powers up at 1.44VCore and after that, it provides the setting that have been puted into bios(1.6V moded 1.9V)......Problem is that I'm still searching to find a way to feed it over 1.91VCore.......I though that the Northbridge chip couldn't handle the voltage, which also been feeden with 1.91Volts via VCore so I seperate it and I feed it with another DDR Maximizer of mine but no go.....Same thing happens......IF I don't find any solution about that any time soon, I'll be forced to feed the DOTHAN's core via another DDR Maximizer....... ;) :)Quote:
Originally Posted by wowza
How many current can a DDR Maximizer handle ??? Dothan's aren't as power hungry as Prescott's but that will be alot more current than some DDR sticks. Anyway if it works, it'll be wicked cool :cool: And you are HiPro .... :)Quote:
Originally Posted by DaWaN
It can handle up to 125Watts normal and 160Watts+ peak........
That will be just enough :)Quote:
