:eek: 1.552 Vcore on water - no comment:
http://img355.imageshack.us/img355/8767/15527wn.jpg
:toast:
:toast:
Not much to be said :toast:
http://www.gratishost.dk/uploads/3000(Large).JPG
No, nice Chip but only SuperPi 32M. You are testing the Ram?
Prime 95 V 24.14 would be nicer. Here´s a List with 0547GPMWs with minimum 2Hs Prime 95 V.24.14 Custom FFTs In place.
http://www.forumdeluxx.de/forum/showthread.php?t=197362
Yeah, it would... I'll work on it!
HCC, one comment though:
Wanna trade?? :D
Sweet chip mister, KAB3E 0547 GPMW?
:( Bad luck here, only average clocker - doin' 2.5 with 1.39 and 2.8 with 1.52 volts. Nothin' to get excited from........., so throwing it into EBAY.....;)Quote:
Originally Posted by Zeus
:toast:
My mistake, on closer look i saw it is your Opteron.
Too bad about your 0547GPMW, the first not good clocking cpu with this stepping i have encounterd so far.
I've been offered 2 so far, both heatspreaderless and both doing 3.2GHz Prime stable but both for an unfair price unfortunately.
:rolleyes: Yep - I still wonder if it has to do with the fact it is a "tray". And I saw that the batch in front of the "L" is 1376xxx. All the fine clockers are labeled 1377xxxL5xxxx.:confused:
:toast:
1377677 are the best 0547GPMWs but they are SD 3700s.
Also availavle are 148er Opterons.
CAB2E0547GPMW
137562AK50XX
Also not bad.
are these CAB2E/CAB3E and any others as long as they finish with 0547GPMWQuote:
Originally Posted by Rufus7
i can get CAB2E 0547GPMW...........
so you guys think 1377xxxx onces are good............have you guys seen any shyte 1377xxxx chips
also can you confirm
WAKÜ = water
LUFT = air
in terms of 1377xxxxx chips i know that Kenetixx's chip was this stepping at it topped out at 2.8GHz :confused:
http://www.xtremesystems.org/forums/...&postcount=230
ADA3700DAA5BN
KAB3E 0547GPMW
1377569L50674
waku = water
luku/luft = air
have you got some results for these......you can link......as they are accessible in land of OZ :toast:Quote:
thanks bvk...........yeap i recognised Luft....so thought the waku one must be water.....hehehe
Yes Dinos Wakü is Watercooling and Luft= Air.
And i have bought at Funcomputer an Opteron 148!
www.funcomputer.de
www.overclockers.de
www.trend4pc.de
www.bay-zone.de
Some Shops for interested Buyers.
CAB2E0547GPMW
137562AK5024X
Pretested on Air with 1,5Vc and 3Gig.
Not bad but the Heatspreader not the Best. Have to put it off.
Then we will see.
And SD3700 KAB7E0547GPAW
1380567L5007X
are also no bad Overclockers.
Have reached until yet 3047Mhz 11x277Mhz at 1,408VC without HS and Watercooling.
http://www.bilder-hosting.de/tbnl/AQ3BX.jpg
Hey now we're talking about the CAB2E 0547GPMW, i had one (sold) and it was great, did an OCCT at 3.2 Ghz on water.
I should also point out the CABQE 0547GPMW, which i'm running now. I have gotten 3dmark01 to pass at 3.1 Ghz on the stock cooler.
Basically
ROCK ON WEEK 47! :rocker:
week 47 winchester CPUs were strong....if anyone remembers.....i had a 0447 winnie myself :)Quote:
+1Quote:
Originally Posted by dinos22
3200+@3140mhz screen on Air box amd :woot:
remember :rolleyes:
woww:woot: fx57 killer:D
Theres only One FX57 Killer known!
And that´s Stonkas KAB3E0547GPMW 1377677L501XX.
He can go up to 3320Mhz and 1,53Vc under Watercooling and Prime95 Vers.24.14 Custom FFTs in place Stable.
Other 0547 is unknown under Water.
To reach this Result others needs Phasechange or Cascades or DI.
too bad they're cold bugged :rolleyes:Quote:
No Dinos22 they are coldbugged but they are running higher on Water.
And if you can use Chilledwater you can throw your Phasechange away.
Like a Aqua Medic Titan 500 or 1500. 4°-24°C cold water can bring you a lot of Fun if your Chip is coldbugged.
People!!! I still have BOXED AMD Cooler and using it daily. My CPU is never under 40°C and about 55°C-59°C full load. Can I damage it?
Benching with higer v-cores it even reaches 65°C-69°C.
65C is the max I thought O_O !!!Quote:
Originally Posted by Punisher!
Zalman 9500 is in your future methinks...
What I means is:Quote:
Originally Posted by Ator
- is it possible to damage it and making it in the near future work at the same frequencies but with higher v-core or something similar or the truth is that "or it works, or it doesn't work" :D?
Hi guys I just recieved my 3700+ sandy...
KAB3E 0548 BPCW
Serial Number: 1377xxxL50006
Should this be a good OC'er??
Got it from Scan computers if anyone in the UK is interested!!
Tyranus nice.
But your Batch L50006 is not so important.You can post L5000X
Wafercharge ID is more interesting 1377677or like these Numbers.
KAB3E is nice!
Best Sandys 3700 have KAB3E 1377677L5015X Wafercharge ID and Batch is around 150!
Would be great if you can Post the 1377---.And your Results on Air or Watercooling.
THX
