oh ok thanks alot ! =D.Quote:
Originally Posted by chefnr1
did u used the original spd to replace the bad one? if not this could be the problem!
The problem is that the taiphoon doesnt see the bad mem it's invisible it find's only the good mem the other bad stick is like it's invisible and i'ts only on my DFI U-D that i can boot with both sticks in. and i have saved a dump from the good mem and the spd is ok on that, it's just that the bad one dont show up. :(
so it only sees the good spd or both?
yes only the good one,and only on my DFI U-d board on other boards it's only beeping when i try to boot with them in the slots very strange i think..:confused:Quote:
Originally Posted by Waus-mod
yes only the good one,and only on my DFI U-d board on other boards it's only beeping when i try to boot with them in the slots very strange i think..:confused: but when i only have the good one in on the other board it boots just fine...Quote:
It may already be in this thread and I missed it, but there is Ver 2.0 out.
http://www.softpedia.com/get/Tweak/M...n-Burner.shtml
Thaiphoon Burner is the first known software that provides the easiest way to edit and flash SPD of RAM in Windows without using any additional hardware components! The second version supports 8 new Intel ICH7 series peripheral controllers, nVidia nForce 3 250GB and MCP55 controllers. In addition, Thaiphoon features an enhanced HEX Editor that enables to move the cursor by arrow keypad.
Was wondering if anyone had a dump for Mushkin EM3200 (PC3200) 1GB stick running 3-3-3-8 @ 200MHz.
I am running three sticks of ram on my NF7-S, two of which are OCZ UTT 512's and the third a gig of PQI turbo.They run together on the latest Abit bios at 200 mhz with 7-3-3-2 timings. They will not run any other speed without errors, even 201 mhz.
The timings on the OCZ were not matched to the stickers on the ram.It is marked 7-3-3-2.5 but the spd says 8-4-4-2.5. The PQI Turbo's SPD is 5-2-3-2. I am aware that the fastest timings on an NF2 are 7-3-3 and all sticks are capable of diong that up to 216 on their own at default voltage. I am thinking that the vast difference in SPD's are keeping them from going past 200 together.
Do you think that flashing all of them to an SPD with the same timings would allow them to run better together and pass the 200 mhz barrier?
<font color="red">people. you still need to watch out with re-programming youre spd with other spd's then original. There are second spd's that you CAN'T reprogram but still work! this can coz problems, where i dont want to be responsable for!</font>
It is not uncommon for the SPD timings to be more lax than what the ram is capable of running in order to increase the compatibility with more motherboards. You first boot at the more relaxed timings per the SPD, then you adjust them through the BIOS to the more aggressively rated timings. I don't think this should be a concern for you.Quote:
Originally Posted by shadowdr
You know wht they say about where angels fear to tread. I did try several flashes of the 512's without any help for my situation and did notice that on one module the part number would change while the other stayed the same. Strange that that would happen but did not seem to have any affect. Great program though for someone with serious compatibility problems or dead ram.Quote:
problem is your chipset.Quote:
Does anyone have dump for crucial ballistix BL6464Z402 (512MB) ?
does anyone got the dump for 512MB Mushkin PC3200 Level II (990989) ?
Link not working ATM... I work at a computer shop so I could dump many sticks SPDs including high-end memory, could be useful for the community!
nm.. new version:
http://cbid.amdclub.ru/files/thphn30.zip
Resoldered SPD chip, rewrote SPD and saved bh5 module :D
But this is only if your SPD is totally dead.
maybe you guys can help me
i've got 2x512 Twinmos AA4T CH5
they run 255 2-3-2-5 with good alpha timings
but there is a problem with them ..
my pc doesn't want to boot with them everytime (DFI gives me 3 red leds error)
sometimes it will turn on ... usually after a long wait before pushing power button (around 30minutes) .. then i can do every thing (they run normaly as allways at 2-3-2-5-1T rock stable) accept powering down my machine ... 'cause they will not boot again :/
both stick act like they were dead on other motherboards :(
when i stick them in yellow slots and some good ram in orange slots, system boots up perfectly but doesn't see those AA4T sticks .. however CPU-Z can read SPD from every stick...
http://chaos.dracopc.com/pub/ch-5_problem.png
i tried to reprogram spd with thaipoon .. but after reboot they are like they where before .. :(
anybody can help me?
p.s: sorry for my english :rolleyes:
Which VDimm do you set?
I have a pair of defect Mushkin Redlines here, the show similar thing, the don´t boot most of the time, need more VDimm to wake up.
Do you run your DFI with 2 x 512 and 2 x 256?
i set vdim 3.3v + 0.03Quote:
Originally Posted by stummerwinter
@3.4v and above i got errors in memtest and they are unstable
and YES .. my DFI runs with 2x512 and 2x256 perfectly .. but with 2T...
Before i go to sleep I removed 2x256 and i put my 2x512 in the orange slots...
I wake up this morning pressed power on my PC ... and voila ... I'm in Windows now with 1gb of ram..
http://chaos.dracopc.com/pub/ch-5.png
i don't know why they behave like that :(
I can add support for nForce 410/Geforce6100 if you need.Quote:
Originally Posted by kiwi
Used this on my Geil One BH5 and returned a stick of my finest bh5 from the dead cpu-z had some how rewrote its size to 16180mb if only it was true lol
thanks Waus-mod
Anyone need a dump of Geil One bh5 512mb stick p.m me
To VVJ:
Can you add support for Geforce6100/nForce410 for me ,please? I'm using Biostar TForce6100,my email:ahxxy0378@sina.com.Thanks!
Can you guys help me? The program can't work on Biostar TForce6100 with Geforce6100/nForce410.THX!
Thaiphoon works on i845D well (a lenovo's PC,QDI motherboard,Ramaxel's DDR266 memory module).
