If i do same, i have corrupt image directly... so i think it will use only 1.35Quote:
Yes,vgpu voltage is increased in 3d only when ccc is opened.If you set 1.35v without opening ccc it will stay at 1.35v even in 3d.
Thanks man, no wonder i was crashng at 730, lol ill leave it at stock, and see what happens!
One thing I'm wondering, if you make changes in CCC to do with setting AA/AF levels, avivo colours etc will these changes on take and stay in place if you have CCC load on startup of windows or will they always be in place even if I choose to not have CCC open ever, especially on windows boot. I have CCC set right now to always open on startup however silently in the background with no taskbar/quicklaunch icon. If CCC only is causing the voltage bump then perhaps not having CCC load may cut down on my temps a bit keeping them below 1.48v in 3D full load.
I have to ask as well, anyone with the OC/PE bios finding stability issues if the voltage does NOT go up to 1.48v during 3D mode or does it still run totally fine at lower volts? Cutting down on heat is a big priority for my hot card however I want to maintain stability as well. It is running just fine as is.
Thanks.
My card with watercooling mcw50 is benchable to 785/800.
If I get temp down a little its benchable up to over 800/800 since the card do produce a lot of heat.
used open doors and lower the temp by 10c and things worked a lot better ;)
Now, I got to figure out a way to get the water cooled better.
Into the think tank then. :D
Get a small dorm style fridge and drill two holes in it and put ypur radiator in it. See if that helps:D
:eek:Quote:
Originally Posted by ugp
LOL.
Yea, now I go hunt ;)
x1800xt goes hot all I say..
What is the temp. idle you have, before and after set the right voltage.?
I m curious.
Can some post the standard bios file for the X1800XT please, or link where to get it. Sort of deleted mine :eek: :slapass:
Man I have seen pictures of people doing that before and using Alcohol in the tubing so it doesn't freeze.Quote:
Originally Posted by flopper
YOu can use Ethanol on watercooling tube, with anti freeze liquid ( for car rad.) for neutralize first the fire risk..
The result is better with this type of liquid as simple water, the water heat is really reduced.
My Club3D X1800XT Bios ---> LinkQuote:
Originally Posted by reetzy-SLI
My card is with XT PE Bios 765/800 (overdrive) benchable with stockcooling...
Can someone send me the ORIGINAL bios the the Sapphire X1800XT......Thanks....
hipro5@freemail.gr
Finnaly broke 10k.
10218.3dmark05 result
Changed my mobo to a gigabyte so I could turn upp the vcore a little more.
an 3800+ x2 at 2543mhz and a 795/800 isnt to shabby.
And also cracked the 30k in 3dmark2001 heh, ;)
High tech solutions isnt for me, watercooling is enough without going to hassle for some phasecooling ;)
But when I get a house some ideas there is to cool down using water...
But that is for a later day.
THATS IT! Watercooling after the first of the year for me! I have made my decision...
Are those results 24/7 stable use?
I use 720/800 för 24/7 use and gameing.:p:
No idea to stretch it since the cards runs hot.:devil:
I get artefacts at 810core.:fight:
I could prolly use 770core or so but better safe than sry.:worship:
:ROTF:
Yeah, and a way of how to enable the mem-slider to go beyond 800 mhz. in the CCC overdrive tab. :rolleyes:Quote:
yep but in this case we need too a good software for set the voltage, i need really increased Vmemory and core passed a certain speed..Quote:
Originally Posted by Apple740
Gee......I LOVE XS.....Everyone is HELPFULL in here......Guys THANK YOU for the bios you have sent me......:) :toast:
The new ATI-tool 0.25 11 beta is compatible now X1K, they have fix the problem 2D/3D clock,... in real opening the soft, the soft set directly what you need for OC....
the result is nice 3D'03 & '05 increased for me at first bench launch:
3D'05: 10'822 http://service.futuremark.com/compare?3dm05=1620121
3D'03: 20'110 http://service.futuremark.com/compare?2k3=4506855
Nice stuff!!
could you post link to 11 beta.
i have flashed my 1800XT with XT PE bios and there is no difference in default clocks, readings with ATi tool. Before and after I have 600 700?
is this normal or is there problem with ati tool?
p.s. found the link http://www.techpowerup.com/downloads/172
Yeah yu can find it too, on www.Tweaksrus.com, You can find too the warcat 5.13, i have use the beta4 of this version for bench, the final is based on this "beta4" version. (Tweaksrus Innercircle member/ beta tester)
(For peoples having prob install with a 9600 there's a fix patch on forum.)
For respond to you, the ATI tool allways see only 2Dclock, open your CCC and overdrive and you will see the 3D clock set at
700/800..(PE stock speed 698/792, but the 2Clock is same as the original bios,594/694,... 2Dclock before enter 3D mode)
It's what they have fix in ATI tool you don't need anymore disable the ATI smart & hotkey poller in service for OC, it do it for you, cuting a *.dll when you launch the soft... this made you set voltage and can set the clock speed OC directly, using the soft.
( i have set directly the voltage i need, so i have not verify all, and if the voltage is set right enter the bench.. but like i need more voltage when OC the core and memory... so no prob for me.. )
i have installed 11 version, but there is no change. How do i enable overclocking in CCC? i don't have it or i can't find it!
what are the stock volts on an X1800XT in 3d mode?
i have mine at 1.4v and I fear that it's too high
stock with stock bios, ati tool reading i get 1.275
