What do you guys think the OC potential of a 165 CCBWE 0534SPMW would be on air? (Ultra-D, Ballistix, Big Typhoon).
2.7-2.8 easy..Quote:
Originally Posted by Confusion
2.8-2.9 if you are lucky
my x2 3800 is sold and i just pulled the trigger on a 170 retail from mwave, i'll you guys know how it goes when it gets here.
Has anyone confirmed this problem on the regular ultra-d? I thought it was only the eXpert that had the problem of killing cpus. I think its kinda odd a huge problem like this is just recently discovered on a board that has been out for over a year.Quote:
Originally Posted by shiznit93
Perhaps you didn't notice that last Sunday the 170's OEM were $366 ;) +$50 in a week just seems the vendors ask for this :slapass:Quote:
To keep things in perspective, the OEM 170 I just received from Monarch is a CCBWE 0534SPMW, and at the moment 2.7 SuperPI 32M stable is the highest I can get. I have an XP90C with a good panaflo on it. So, the Big Typhoon might get you more. Load Temps are about 53-54c and voltage needed for 32M stable is about 1.55. I'm not really willing to go any higher on voltage with this cooling. I never seem to get the super chips that some folks around here seem to get, so I was expecting 2.5-2.6. So, I'm happy.Quote:
Originally Posted by demenion
I'm trying a burn-in at 2.2 at 1.25 volts to see if I can get 2.7 stable voltage down some...
Rob
Originally Posted by ixtapalapaquetl
dual core 175
Bios 1.35 X 110%
CPUZ 1.424
idle DMM 1.493
dual p95 DMM 1.524
holy $hit, this is not good. where exactly are you measuring the voltage, i have a very good DMM and wanna try this myself.
LOOK HERE
CBID shows it under the p-states tab, 49C on my 175Quote:
Originally Posted by furyfax
i always said the vcore is more than you think on the dfi's ;)
more to the point, shall i go for a 165 = £230 or 170 = £290 ??
I'd say 170 if you want the chance at the golden stepping, 0530TPMW.
You can OC these to the speed of a stock FX-62 (DC 2.8ghz) easily, maybe even push up the volts to make it 3.0ghz (FX-64) :p:
yeah and with 2 cores...hmmQuote:
Originally Posted by edma2
DAMN!!!! i ordered an OEM 170 last tuesday (shipped thursday)Quote:
Originally Posted by fargusmax
i was really hoping for week 0530 :(
Yea, I was hoping for 0530 myself. But I don't think I'll be raising any stink because I can only get a 700mhz overclock...Quote:
Originally Posted by SubZeroGTS
Rob
Anyone from newegg.com or zipzoomfly?
Monarch shipped my two (OEM and retail) last Friday... but I'll keep my fingers crossed. It's weird that I can never get the good steppings regardless of how soon I order them.
I orderd a 170 oem saturday morning (from monarch) hoping for a 0530, guess it won't happen, since i don't have too much good luck. it was like the only reason i ordered one too, see how well the 0530's were doing :(
I think we should give up on 0530 if none of us get any.
hey guys when your talking about these opties getting 2800mhz and such are you guys talking on air? just asking cause i just picked up a 180 dual core and im expecting atleast 3gigs on phasechange... my 3800x2 will run 3300mhz on phase i would hope these opties are good for atleast 3gigs using phasechange...
btw: the 180 optie i scored is a 0530 TPMW so if this is the stepping to get i hope its a good one.
thx perc,
Mine does 2.9 (Prime crashes) on air and it's a 0534SPMW.
thats not bad actualy i wouldnt doubt one of you guys getting 3gigs on air with the right stepping... ill post some results once i get this thing. ill be running mine under phasechange (stock vapo ls ) so i hope for atleast 3gigs maybe even 3200mhz just depends if the oc gods are smiling down on me or not :) .
peace perc,
My 170 CCBWE 0530TPMW did 2.8 before I had to touch the voltage (1.32 stock) and 2.9 prime stable for ~6 hours. It was pretty stable at 2.95 (spi & some prime) and I was pushing for 3.0 when my mobo died! Doh! I have good circulation and lots of fans (memory and pmw fans besides the xp-120) but something still gave. There is no obvious damage but it is definatly dead because I switched everything else out with a friend. Figuring out now if I can RMA it.
SPMW can do 2.8 and up with 1.550 only. At some point I had to play around with special VID to get it higher than 1.550 to do prime at 2.8.
I still have some tweaking and testing to do. I'm hoping for more than 2.7, but I just don't see that happening.
How did your board die? Was it b/c of OCing the 170?Quote:
Originally Posted by jsriolo
woohoo got my chips.
Hoping for 2.6 on the opty and 2.4 on the X2.
if I hit that I'll be 100% happy.
http://ls1archive.com/hard/cpus.jpg
