Newegg has them for $270 if you dont mind the :bananal:
The GTO2 I got are lite version too...
damn 270US $
they are 225$ @ suppliers...should be around 270CDN$ on webshop... :slapass:
I ordered my x800gto² lite for 215€, thats 257US $
at least...it's a cheap X850XT :rolleyes:
Would be nice if they could run CF .. 2 * X800GTO2 @ X850XT in CF would be great performance ...
yep im using one , i forgot to take a pic for youQuote:
Originally Posted by TEDY
yep please pancake...did you applied AS5 for memory as well or just used those blue ramsinks?
i just used the ram sinks with the sticky pads , when i have more time i will remount them all with as5 and some thermal epoxy. using as5 on core though
I just purchased Vantec IceBurq ramsinks for my card. I hope I can OC my ram to GTO2 levels, or at least higher than 1080MHz
mine do 630 (1260) with just the zalman sinks no vmods
Hate to keep spamming this thread, but can anyone post what week their R480 core is/was? Thanks.
I will tmoz or the next day when I get my ram sinks. when I get them im takin off my HS (connect3d) and will be postin pix0rs of the heatsink on the bottom, & core :D.
I've compared my score with this one: http://service.futuremark.com/compare?2k1=8755007
This is my link:
http://service.futuremark.com/compare?2k1=8753834
My CPU was clocked to 10x250 2-2-2-5.
Why is my nature score so high?
My Card was at 550/625, this is the highest I can do with stock cooling, my core sucks, but the Mem is really good.
http://666kb.com/i/10v3blrdnha0w.png
The one you're comparing to doesn't have an unlocked core.....BUT more MHz on the CPU making the scores close. Your higher Nature makes up for your slower CPU.
Originally Posted by 187(V)URD@
Where did you ordered it ? I'm from belgium too, the cheapest I have found was ~250€ in germany , too expensive I mean.
thanks.
I've bought my GTO² in Vienna, Austria, for 239.90€ now the card is at 259.90€ at the same shop. :banana:
www.descom.beQuote:
Originally Posted by tomati
Where can i find these memory tweaks?Quote:
Originally Posted by einCe
@ 187(V)URD@
thanks man.
OK, I'm all set to vmod! I've got a day off work, a conductive pen, some 2b pencils, a multimeter, and a healthy apprehension about #$%ing with expensive electrical equipment.Quote:
Originally Posted by LexDiamonds
To get over the latter can I get some confirmation that that guide is the right one for the GTO2?
-aMp-
amp please take pictures :)
cool the mem tweaks work and no artifacts for me.
run done with a 3200 winnie @2.7 512kb cache ( old run was with a X2 1mb and got 7015)cache , reckon i would of been around 7100 with x2
the techpowerup guide is what you need...
I'll vmod my card this weekend...wish I'll get my ATI silencer...
How can you calibrate the voltage with a pencil mode ? :confused:
amp : what kind of cooling ?
