i wonder if the performances of this mobo can be better than my sli-dr in oc :rolleyes:
if it does imma sell my sli-dr :D
What will be the difference between the CF-DR and the CF-BT except the coloring?
The CF-DR is not available and almost 3 months late, same for the CF-BT. No differences there :)
lol memory voltage up to 4V :slobber:
Ok , finaly in Germany can pre-oder this mobo . So i have a quetion for DFI Rep : Does this mobo can adjust Vtt like the Sapphire board ? And how's about the NF4 Expert ?
The only reason I might consider buying one of these, is the nasty VTT drop issues on at least some DFI nF4 boards (apparently, mine as well), for which no simple solutions, which could be done with basic vmodding/soldering skills, are known yet. For discussions on them, see the Xtreme Motherboard Vmods section.
Looks to me like they are using the ati designed gruper power design, so the 4v shouldnt require a jumper, and aughta be pretty solid atleast... :)Quote:
Originally Posted by mrlobber
$270+ tho.. ouch :( I like the $130 ultra-D....
I preordered this mobo so results shouldn't be far away :banana: :banana: :banana:
jort
for what price?
233 euro inclu ship;)
Originally Posted by Jort
:doh:
Man DFI is just gonna put its price up there as many are anyways going to try out :( Let us hope it is clear of many of the bugs with NF4. Well waiting for the Test report by fellow members :)
Didn't see anyone post this yet but if you want to be informed as soon as they come in at ZZF, here is the link. The board is kinda spendy though. Even more so than the SLI-DR Expert, I "ordered" at NCIX.com.
http://www.zipzoomfly.com/jsp/Produc...uctCode=246500
Kind of costly? that is kind of like saying Mike kind of got carpel tunnel from Hustler kind of...Quote:
Originally Posted by 20AEGTI
Is this DFI LANPARTY UT RDX200 CF-DR RD480+SB450 Athlon 64(FX)/X2 Skt939 DDR ATX Motherboard w/Audio, Dual Gigabit LAN, Serial ATA Retail: http://www.zipzoomfly.com/jsp/Produc...uctCode=246500 better than the DFI Expert? What are the pros/cons if any?
So that is where I got that from? :D
The definition of spendy is proportional to the depth of ones pockets though. To some that might not be too bad but too most that is a little steep. Just bare in mind though that is pre-release pricing. Who knows by the time it comes out it COULD drop.
Originally Posted by nn_step
or it could go highier due to lack of availablity..
Originally Posted by ninja_xxx
Enermax Whisper II 535W got a 8 pin connector :)
PCP&C 850 SSI would be a much better choice
nice but is a little large :p:
Link for the LANPARTY UT RDX200 CF-DR at DFI's site. Looks like the expert is also released on there products page. Either one of these is a winner. I bet ill get the Expert, as im a bit shy for the first run of the Crossfire board.
Cheers :/ :toast:
I figure if you have the money for it, you have the money for a half descent case to put it in.. OR atleast mount it ontop your case... :PQuote:
Originally Posted by serker
In stock and available now in the UK.
http://www.ebuyer.com/customer/produ...duct_uid=97308.
Storage
1 Floppy port
2 parallel IDE ports with up to 133Mbps UltraDMA
4 SATA-1 IDE ports with up to 1.5Gbps with RAID 0/1 SiI 3114 supports 4 SATA-1 IDE ports with RAID 0/1/0+1/5
GEEEZZZZ! Only supports SATA 1!!! OMFG. A brand new model with SATA 1?
What is this? Collectors edition? :stick:
The ATI southbridge doesn't support it. The ULI 157X those however so many manufacturers has chosen to use that for the crossfireboards instead. Like MSI.Quote:
Originally Posted by MonkSP
