Sorry , but I did not know anything like what you said ...
If you use 5V jumper to select the voltage higher than the DRAM or CPU can handle , either your CPU or DRAM will be damaged ...
If the high voltage cause the current over the MOSFET limit , the DRAM regulator may be damaged ...
But that number will be 53A continous when the MOSFET working under 100 degree Celcius , the peak current this MOSFET can handle is above 200A ...
The MOSFET we use in DRAM power regulator is PHILIPS PHD78NQ03LT ...
http://www.semiconductors.philips.co...78NQ03LT_4.pdf
Anyway , all these are expected to happened when the board released ...
We have put enough warning about all these thing ...
Please be understand that the NF4 chipset is not power by DRAM voltage ...
Also DFI or any other company will not gurantee or be responsible to anything damaged when you set voltage beyond the chip spec(cpu , dram , chipset , pci-e graphics or anything else ) ...
I don't know what you hear from DFI SJ , but I never say anything like this to anyone in DFI SJ ...
