Where did you read that? 8c hmm if thats true then that means im doing 32 idle - 46 load... sounds better with the type of cooling I have, I dieing to test with higher voltages, but they said bios 1.8 read temps right, but temps have been the same with all bioses i've tested. Now i'm hoping for 3200mhz stable :slobber: :banana: :banana: :banana:
I've attach a thermal probe to the side of my heatsink where the heatpipes come out of...and i'm getting reading of up to 18 degrees lower. I have my tornado practically turned off. theres like 3 degrees diffrence between idle and load... even if actuall temps are 5 degrees higher... thats still good right?30+5 and 32+5...thats sound more normal my 3.0ghz c used to do no more then 40c with a thermaltake spark heatsink. whats the max vcore I should try?
