:confused: Maybe Your Winnie contains a bad memcontoller.....?Quote:
Originally Posted by HitMaker
:toast:
:toast:
I dont know, with my OCZ El Plat rev2 TCCD y could do 300x9 1:1 :rolleyes: , so i don´t think so.
I will try again and also maybe some burn in..
By the way, what bios do you recommend me??
:D Get the 510-2FIX - working best for me.
:toast:
Thanks :p:Quote:
Originally Posted by HARDCORECLOCKER
By the way, Drive Strenght y Data Drive Strenght (which levels do you recommend me to set them at?), TREF 3684 is ok also?
Thanks for your time ;)
Finally:
http://www.telefonica.net/web2/hitma..._memtest86.jpg
3.4V vdimm, 1.37V vcore, 1.3V vldt and 1.6V vchipset.
Bios 510-2FIX, thanks HARDCORECLOCKER ;)
Superpi 1MB:
http://www.telefonica.net/web2/hitma...ncrono_1mb.jpg
strange things:
-Idle Cycle Limit, only if i set it at 16 it works, if i set it at 256 give me a hundred of errors :roll: :confused: . Also tried 008 and 004 with thousends of errors.
-Finally was able to set Drive Strenght to level 8 and the Data one to level 2
Tomorrow i will try more, now i am tired (4am in Madrid)
:D Nice to see it's workin' for You - and some regards to SPAIN, the most wonderful country in EUROPE (will move there when retiered ;) ).Quote:
:toast:
Mine are better... :D DDR500 with 3.30v 8M and memtest stable. :drool:
http://www.lifestyleinteriors.org/ho.../DDR500-8M.jpg
Woops I forgot MBM in screen, I assure you all that I am using only 3.30v. :) I do not lie, and only post stable clocks. I will be posting 3Dmark and SuperPI 32M results later anyway so you can see proofe then. :fact:
SO bios 704-2 (i can see it in your signture), which slots???Quote:
Originally Posted by blackjok3r
Maybe is time to change to a SanDiego 3700+ :roll: for better mem controller :stick:
using yellow slots, as I can cool ram better with those, orange is too close to Freezer64. But this bios is just amozing how good it is. I takes less volts to do equal clocks with my old bH-5, which I must say are exactly identical to my gskill GH. Infact to setup GH, I just removed HyperX and inserted GH and booted up, stable as. Well as close as possible as theis crappy board can do to stable. CSS and other games don't work (board is faulty I think), 3DMark's are fine though.
:toast: :clap: :banana: :D ;) :p:Quote:
I think almost the same :P
Just a heads up for you guys using 704 you need to becareful. Oscar Wu has reported it having voltage problems and asked it be removed. Read about it here http://www.dfi-street.com/forum/showthread.php?t=16500
Who cares! Just dont use VID % thingies. :confused: This bios is awsome, did some testing today with 3.4v, was hitting 260Mhz memtest stable. :slobber:
This ram is awsome wikid cool. :D
hm 250mhz and 3,4vdimm?
here my memory:
http://img180.imageshack.us/img180/2...volt4vy.th.jpg
mfg
i have a problem with this mem i cant get to go at least 250mhz it only stable at 240 no matter what voltage or timmings . i put heatsinks on them i have a 115cfm fan on them also .i know its rated for 3200 but reviews like this and across the web getting 260-275 helped me buy them. i want to send them back but can i return to gkill for a better pair
try each stick independently
i did try that to see which one was the stronger stick but they both react the same
My GH max out at 250 whatever volts . I can only push it higher at 258 by change Cas to 2.5 , so bus 258 2.5-2-2-2 at 3.6v :rolleyes: , i mean it 's stable :ROTF:Quote:
Originally Posted by msimax
not all mem will oc the sameQuote:
just b/c a reviewer or someone on a forum gets super high doesn't mean u will. could be your cpu. your board or yoyr skillz. why should it cost G.Skill $$$ when you got alot more than you paid for????
What do I need to do to disable 32 Byte Granulation ?
My board automatically enables it and it also doesn't have an option to disable it in BIOS, so when I disable it using A64 Tweaker my system automatically freezes or BSODs...
I've seen this setting has slight influence on bandwidth/stability and I know my GH can handle it so it would be nice to have this setting disabled... these are my settings :
CAS Latency (CL) 2T
RAS To CAS Delay (tRCD) 2T
RAS Precharge (tRP) 2T
RAS Active Time (tRAS) 5T
Row Cycle Time (tRC) 7T
Row Refresh Cycle Time (tRFC) 10T
Command Rate (CR) 1T
RAS To RAS Delay (tRRD) 2T
Write Recovery Time (tWR) 2T
Read To Write Delay (tRTW) 1T
Write To Read Delay (tWTR) 1T
Write CAS Latency (tWCL) 1T
DQS Skew Control Increase Skew
DQS Skew Value 0
DRAM Drive Strength Normal
DRAM Data Drive Strength 4 (No Reduction)
Max Async Latency 5 ns
Read Preamble Time 4.0 ns
Idle Cycle Limit 16
Dynamic Idle Cycle Counter Activated
Read/Write Queue Bypass 16
Bypass Max 7
32-byte Granularity Enabled
just got a pair 2day, reached 265mhz 1,5-2-2-5 - 9 - 10 ;)
But got better results using 1,5-2-2-5 - 10 - 14 in SPI quite some difference actually..
- 12k
Hmm another thing... Tref at 133mhz 7.8us gives me one heck of a bost, gained 1,4 secs !?!? Compared with 200 1,9xus...
Futher I gained lots by using 0 clk in Idle cycle limit - compared with 256..
- 12l
I just found out it is only when i have them in dual channel.
Alone they botj do 250 3,3v wihout to much testing. Anybody knows why they are not stable in dual channel? Or must i open a new threat?
The bios for the nF4 DFI boards are can be picky with certain types of ram. Try updating bios to newest date, and then try -1, -2 and -3 and see which one seems to work the best.Quote:
Originally Posted by [MsT3r]$eR9!o
Also, Try switching from Orange slots to yellow slots or visa-versa to see if you can get dual channel running smoothly.
My mem just did 9 hours of prime95, stable at 250mhz in dual-channel. But in memtest it gives errors.. So i think there is the problem. My memtest is corrupted or something..
had my g.skill gh today and little bit fun
http://i3.photobucket.com/albums/y90...2-5255mhz3.jpg
my p4 is holding me back was not stabel in windows like super pi but can do memtest like hell
cpu vcore 1.41 in bios
ocz booster 3.4v in bios 3.45v
next time tis wil be stabel :banana:
