Quick Question on this board, I just need to add a third monitor to my set up just for desktop space. I am trying to enable the onboard video as well as the pci-e but I don't see a PEG option on this board? Is this possible to do?
Testing another new kit of memory's tonight,this kit is quite strong at 2800Mhz not quite as strong when pushing past 2800mhz,well it did boot to windows @ 2880Mhz 6-10-6-24 tight wasn't 32m stable :)
Is good for 32m 6-10-6-21 2800Mhz tight and also 1m stable at 2800mhz 5-10-5 2800Mhz tight :)
2.25v -160 PSC 2000 Pis cl6
http://i61.tinypic.com/sczuyt.png
2800 CL5 :shocked:
very nice bullant
Thanks Loud,sergmann ,got a kit of 2300 pis that I've only used on air that are quite good will test them today on cold see how they go
Here is the other kit that ive never tested on cold,board trains and works well
Pi's 2300 cl8 -160 2.0v 6-9-6-2800 This kit seems quite good but with limit of 2.0v could really hold this kit back,does pass 32M 6-9-6-21 -1755Mhz,should pass 32m 2800 6-10-6
http://s1.postimg.org/net29zodb/cl8.png
6-10-6-2820
http://s29.postimg.org/qmb58p4yf/cl8x2.png
time to play with samsung
http://abload.de/thumb/20140914-2251181luuk.png
Nothing special with this bios, but here it is :)
https://dl.dropboxusercontent.com/u/...Z97OCF012c.rar
^ Thanks
Bullant how low temp did you have for 2800 cl5 on the dimms.
So decided to have play with 4ghz tonight,had couple faster runs but just fail at the end,will try again later push bit more
http://s23.postimg.org/u2835fa7f/567.png
http://s10.postimg.org/qjntkmkpl/44443.png
Little update on 4Ghz,some cl5 :thumbup:
http://s15.postimg.org/pykv0whzv/opl.png
Question about SLI on this board. Can I run SLI with PCIE1 and PCIE4 and get 8x 8x?
I see in the manual it says PCIE1 and PCIE2 for 8x 8x, but just a setup question for when the board arrives.
Thanks.
Yes you can.
I rmad the board 2 weeks ago, so stupid to rma a board like this for pci-e speeds not working.
Testing few other things tonight,this passed 4 loops with out wazza :)
5-9-6-21 -2800Mhz tight subs
http://s8.postimg.org/46fo7r45x/image.png
Took me a while, but yep, that was IMC related. Combining stability testing on a new chip with checking timings - tWRWR_dr 5 now running smooth.
So next thing, I was seeing weird default voltages with that Pentium. Default System Agent after CMOS Reset (no mem OC) is set to 1.000V, testing for stability with the usual +20mV was a total disaster.
Turns out I have to set an offset of -145mV on SA to be stable at 2666 memspeed (Timing Configurator also open on screenshot). Anyone ever had that happen?
http://abload.de/img/1350_customdkj45.png
Way better with XP, 1.95V. This was with the old chip, so still only using tWRWR_DR 8
http://abload.de/img/5000_6_04_344srjzx.jpg
5ghz Run with xp :rolleyes:
http://abload.de/img/20140925-162253tdjny.png
New bios here . It might help 3D performance and cpu score
Lots people ask about C-state . It is better to disabled it if you want better performance.
http://picx.xfastest.com/nickshih/asrock/Z97OCF112D.rar
Nice 5ghz result sergmann :up:
Testing kit of pis 2200 7-10-10,not to bad for low bin kit
this kit also 2800 6-10-6-21 tight,not stable at these clocks yet but ok considering HS are still on the memory's and only -135,should improve a little with more cold
http://s8.postimg.org/x0kq3fdxh/cl7x1.png
Some Cl5 stability with these sticks,HS on -135
http://s2.postimg.org/xirq884yh/cl7x2.png
Alright, I rmad my board due to that pci-e bug, it was successful and I got a brand-new motherboard. But now, while running it it still shows my older 7970 running at x8, same as before. Surely they have tested it for letting the motherboard to pass RMA, so what could it be. If it was the cpu in the first place then how did the board pass rma.
Little play with Pentium today
4Ghz
http://s30.postimg.org/alu7y7x35/image.png
5Ghz
http://s30.postimg.org/6ucu6jjgh/p4x1.png
http://s13.postimg.org/jbiriooiv/DSCN8370.jpg
bull do you can put a larger pics :cool:
