60% faster than the 680...yikes.
Does someone have a direct link for this image from pconline?
Thx. But googlish translation of the text below the picture says that it's just a prognosis.
Whats with the range? This one seems as a more likely possibly score.
so finally this graph becomes true :)
http://i1-news.softpedia-static.com/...es-Surface.png
It better beat the 680 by at least 40% since it is 1.87x bigger chip.
Come on. For $899 we must stick to high expectations guys !!! It doesn't make sense to settle for "realistic" figures. I sure have HIGH expectation in terms of 100% better than GTX 680 for this $900 TITAN. Let them disappointing me, its expensive so it should not disappoint. For this money you get GTX 690, obviously has to be around that performance - anything lower is a disappointment.
ps: To be more precise, this is exactly what im expecting:
http://boxofficebuz.com/content/news...news_full.jpeg
I want SAVAGE performance !!!
http://tof.canardpc.com/view/9ec46ac...7a771b6556.jpg
http://www.techpowerup.com/gpudb/203...e_GTX_880.html
Added yesterday on TPU
Interesting database. Thanks TPU ! :up:
NVIDIA GT 700 Series Kepler 28nm/ Release: 1Q/2Q 2013
NVIDIA GT 800 Series Maxwell 20nm/ Release: ?Q 2014
It's easy:up:
GEFORCE Titan picture fake!
http://www.arabpcworld.com/images/20...CB-APCW-01.jpg
http://www.arabpcworld.com/images/20...Titan-FACK.jpg
translate.google
http://www.arabpcworld.com/?p=26291Quote:
We had all seen late last week the first picture was about it for the PCB your card GEFORCE Titan where the site, which put the first picture exclusively work crystallized be full and the outlets of the card until even the remaining vision is clear contents, consisting of PCB and the focus was on image the GPU and left a clear and written GK110!
If the audit and the opening image of the PAL GPU find Dear reader that the word GK110 modified manually professionally severe but which revealed it is the site of videocardz when easing crystal on the image became clear milestones the PCB a little and was sudden that's modified fully is the basis of image for PCB card GTX285 has been edited Alfaz Bauer added 3 won in return for only 6 MOSFET circuits instead of 9 in addition to the type of the traditional Amoosvi on the PCB and that you did not use NVIDIA a long time ago! In addition sockets 6 +8 instead of 6 +6! In addition to reducing the number of segments of the existing Memory and modify them with the lifting of the metal cover PAL Ocean GPU.
Not forget planning PAL Ocean GPU decree white is Mtzabak them completely with GTX285 in addition to slot 2Pin next to power outlets.
Department of Energy are quite similar in terms of the number and distribution of Alkpastorz especially Alkpastor next to the ports of DVI Port, which was concealed in this way so as not found out is the PCB.
This must be noted that these fake or Fake
I think if someone wrote on a cake GTX780 some of you will believe it....
