ok guys today I went to the shop and grabbed the following: 7750, 7770 and 7850 I will be comparing them with some cards I have currently (a good lot of AMD and Nvidia cards) and giving you guys a full report with graphs and everything in a few days time. I have mid terms this week so I don't have much free time but I will get it done as soon as possible. I will be doing the following tests:
Average Total WU run time on two different systems (one new with a 4.7GHZ 2600k and one old with a stock E6750 C2D) to get an idea on what effect CPU speed has on total WU times
Average GPU only WU run time on both systems
Effect of CPU load on each system (IE running the rest of the CPU fully loaded for CPU WU's and GPU wu's also running)
Effect and times of running 2 WU's on the same GPU
Power consumption of both systems when running GPU (one and 2 WU's) only and when running CPU and GPU fully maxed compared to system idle power consumption
The effect of overclocking each GPU to it's max on times and power consumption
The cost's of power compared to points per day with my power prices (pretty high around here)
Like I said this will take me some time to finish but hopefully this time next week I will have this all done for you guys and hopefully we will get a good baseline of performance and such for a good portion of GPU's on the market
One thing that would save me allot of time is if someone could make me a "app file" or whatever that would allow me to full 2 WU's per GPU and run ALL of the CPU WU types on my CPU for both AMD and Nvidia cards.
I will try to keep you all updated
