X3262 with my gaming facility.... Not that bad :)
i unplugged my ethernet cable and got a result, idk where's the problem for you not getting results or the ability to save them
for msi and antec if you mean in the bench, yes is shows msi and antec, but it's nothing new, the first trailer we got had it
just ran it on the only DX11 machine at my work, unfortunately that consists of a Dell Inspiron with a i5 760 and a HD5450 1GB DDR3:( the physics test on the stock i5 gave almost the exact same FPS as kaktus's run. but the 5450 was a total slide show, most FPS i saw in the whole thing was about 4FPS but most of the time we were talking 1-2FPS and in the second High temple test it was .5FPS
I am looking forward to seeing how the GTX 480 handles it when I get home. Infact i am going to compared my 480, 460 and 5870 and see whats up
Neither do I, I get a "3DMark 11 has encountered an error" dialogue: "Connecting to 3DMark.com failed" with options to copy the error message, visit support site or close the dialogue. the error message reads: "Posting result to 3Dmark.com failed: The remote name could not be resolved..." This is a modal dialogue and when I close it I see no result and do not have the option to save. :shrug:
I just despise advertising and if I am to see advertising in a product I would like a little more than a hamstrung benchmark without any options to change anything. This is just my feelings on the matter and the way advertising is invading every aspect of computing and software. You may or may not agree with me, that's fine. :)
Mobility HD5650
http://img204.imageshack.us/img204/3171/adszxot.jpg
scaling bad in tri, about 67% scaling, so new drivers should raise scores a ton.
http://i18.photobucket.com/albums/b1...430/455345.png
why so much negativity from a FREE benchmark.
paid version has clearly stated all the issues some of you have with it will be gone (online score and advertisements)
try on 6870 soon............
I have the advanced version, but... I dont complain about it, I think the small inperfections will be quick fix.
I like this benchmark alot already, takes about same time as 01SE, its lovely... Unfortunately it is not that sweet as for tweaks, but that might be a good thing, equals out the playing field I guess....
@^ = anyone know how to get a score ?
Great. Let's close threads for rules that haven't been broken yet but ignore blatant piracy.
:party:
Oh sorry. I guess they wanted you to have it early.
what is 11 upgrade?
http://store.futuremark.com/shop/product.jsp?pid=72401
so if I have an advanced 3dvantage key is this all I need? sorry to ask if its already been mentioned I just dont have the patience to read through all the bickering.
OH YOURE KILLING ME. i just bought the upgrade and upon buying it asks for my old vantage key. I did it and it was 14 bux. Youre saying Its free?
oh well. maybe I will get a higher score if I paid for it. I'm stoked to see this in action. I just got my 9800 pro modded for this
http://www.xtremesystems.org/forums/...&postcount=456
Basic version is free, but then you cannot see your scores before submitting - and you cannot submit yet, because it has not been released officially.
I just put in my advanced key, and it started showing numbers for the score, my classmate, who does not have a license, cannot see his scores yet.
BTW; Gathered following details so far...
1) Does not really impact if you have speedstep on or off
2) DOES impact if you change ram divider
3) Scales very well with graphics, especially BW
4) Scales with LOD
5) Does not scale much with driver settings, however, impacted by reboots
6) Seems that clean OS outperforms dirty one quite a bit, just like the old classics...
7) nvidia pwns ATI for this moment HD5870 vs. 580GTX ~30% difference in scores, when both are decently clocked on water or air...
