I first tried sandwiched (note that the fans actually end up taking the full 2 slots even though the pictures don't look it) but the top card was running a full 25c higher than the bottom (around 55c vs. 80c top/bottom during a game). So, I am trying them with the x4 speed, and the temps are virtually identical on each card (within 2-4c now) at full load after gaming awhile.
The good news for me is they ARE very quiet.... I have it at 82% fan speed and it is as quiet as the rest of my case fans for this Gigabyte 1GB pair (dual fans). Color me impressed on that. The other good news is that they run like gangbusters in the only game I've tested so far, BattleField Bad Company 2. Also, I was able to flash them with an MSI BIOS that was modded to allow up to 1.212v (thank you NCspecV81 of XS) instead of the 1.087v normal cap in Afterburner.
Running at 2560x1600 8x CSAA, 16x HQ Anisotropic Filtering (AF), max in-game settings with HBAO on in DX11 mode *AND* Transparency MSAA enabled in the control panel, my overclocked Gigabyte 1GB GTX 460's in SLI are pulling off around 55minimum (usually 60), and 75-80 average FPS for me across the different maps of BFBC2. This is, mind you, with them running at PCI-E 2.0 x4 instead of the full x16, which means around a 10% performance loss from what I have read.
The bad news is I can't nail down a stable overclock yet like I was hoping to that is sky-high. So far I am running 880mhz core on both cards with 3900mhz on the memory... not quite as high as I was looking for, and this is with 1.100v on the cores. They currently max out at around 76c for the pair at these speeds after an hour+ of gaming in BFBC2 with the 82% fan speed (note again that it REALLY is quiet, these fans don't get loud at all ).
1. Try each card single on PCIE 16X to see what it can do each card on their one.
