Hi Jeff, before getting into this project I would point out what I have gotten to work on the W370ET:
CPU works bit is not identified correctly if using Ivy Bridge as there are not being used in MacBook Pro yet, however it doesnt not prevent you from working if using the correct Kext, GPU (forget the Nvidia card it will never work and will need to remove the kexts, using the HD4000, with EFI string and with Internal or HDMI output, non VGA output), USB 2.0, 3.0 (only USB 3 devices and non storage devices) Battery (ish... not very accurate), Webcam (Not the best), Trackpad (using Voodoo PS2 so like a mouse no scrolling or multi touch) Audio doesnt seem to work I have tried a lot of Voodoo sounds methods. Wifi works with a supported wireless card, SD reader doesnt work either. Ethernet works, Might need to edit the plist if you cant access the App Store or is not verified.
As you have probably seen on other post, specially TonyMac, I have to be careful about how I describe the way on how to install Mountain Lion, what kexts are used, using iAtkos and other tools. Unfortunately I haven't had much time, with Uni and work, to work out a way to get the sound problem. I do recommend updating the Bios of the Clevo w370et using a Bios Mod from here -----> http://biosmods.wordpress.com/w370et/ Prema is worked out a way of unlocking the Bios for multiple features... one of those Audio enable/disable, making easier to install MLion, and other things. So for starters I would download iAtkos ML2 from here http://iatkos.me/forum/viewtopic.php?f=77&t=23105 then we can work on how to use it, to install it, you will have to install certain Kexts and mods. Find me when you are ready to try it mate. But I do must say this isnt the best or easiest Hackintosh to get working. I recommend other easier and more compatible laptops.. Nevertheless if you are up to messing about count me in! Good luck!
