GTX470 -905/1810/2050 - 1.175v, water
http://www.pohrani.com/f/T/fe/3oGluA...-1810-2050.jpg
beside the score what, is this a 24/7 oc and what is the gain in fps ?
I have in bios 1.063 full load= 1.145V (multimeter) clocks 830/1660/1060.
Memory@1.620V .
Furmark measured.
U're right it's 4000Mhz mem actually
Pls do not quote my pic
thanks!
953mhz core 1.175v (set v multimeter lead is broken so hard to test) 2100mhz mem
http://i3.photobucket.com/albums/y83...0mhzgtx480.jpg
mcw60 with stock gtx480 plate gentle typhoon 1850rpm x2 blowing over the card to keep vrm cool well i hope they are
storm g5
mcp355 xspc restop
pa120.4 gentle typhoon 1440rpm
17c amb water will be ~21c
Just ordered my 2 GTX 480 SUPERCLOCKED from newegg next day overnight shipping. hopefully they will scale better than my quad GTX 295 sli setup.
The new drivers boost Vantage scores by quite a bit. I'm scoring 28k+ and i'm not even at my top clocks yet.
what aboutfor Fermi bios on techPowerUp! VGA BIOS collection?Quote:
Invalid performance level version
New 257.15 boost like everything ;)
bad company 10+ fps gain on min fps.
those drivers makes fermi even more attractive
http://hwbot.org/community/submission/1007895_
3d vantage preset performance on 197.75
http://img532.imageshack.us/img532/5108/65615573.jpg
and on 257.15 lower CPU because HT disabled
http://img710.imageshack.us/img710/4106/88051766.jpg
from the above ss's it looks like 100% percent :D on the gains with sli in this game,going by my single card gains at least that what it seems to be.
...its time to go back to sli now:)
stock clock 480 920@3.35
197.xx
http://img176.imageshack.us/img176/4623/vanold.jpg
same clocks on 257.xx
http://img37.imageshack.us/img37/7645/vannew.jpg
nice run! mk ultra
Whats the lastest BIOS revision for the 480? mine are 70.00.1A.00.02 and are blue screening in BC2 @ 800/1599/1848 1.025v. (on air, water blocks on the way, waiting for Skinnee results)
Are you sure those clocks are stable? Have you stress tested with the EVGA tools?
Yea your voltages seem too low
yeh your right, after setting it to 1.050v its 100% stable. default is 1.025v! thats low compared to some here ? dont really want to push clock further until under water, the heat from these cards without blocks on 'em is going straight into my tfc triple rad sandwich destroying my nice i7 temps! These things run ridiculously hot
http://www.abload.de/img/vantage257.159502410_sn0yc.jpg
GTX 480, W3520 @ 4,2
NapalmV5 I would like to see a GTX 480 reach 1GHz core clock, now that would truly be an exciting achievement! :eek:
These GTX 480's overclock like champs even though they run pretty hot on air! I feel that if your going to invest in (2-3 way SLI) these hot cards one really needs water cooling to get the most out of these GTX 480's! :yepp:
alright systemlord ill give 1ghz a try @ stock cooler :up:
