omgggg :shock:
omgggg :shock:
Very nice 1m time there, :up: what board you using ?
is that about the max for your nb at those temps? that cpu clock is insane!
Thanks. I would be grateful. :)
Here is my result: http://prohardver.hu/dl/upc/2009-12/13063_prime5.png
It needs rather high voltage for stable 4GHz on air.:down:
...although it's from 0944. :rolleyes:
Insane clocks!:clap:
Here's my second 965 C3, 0942FPMW.
http://www.aijaa.com/img/b/00960/5430221.png
Max stable clocks for this one with Noctua NH-D14 are 4080MHz and for NB 2870MHz.
This one overclocks about the same as my 0933FPMW but NB is weaker than 0933.
Had some Dominator 2000MHz at 1900MHz on one of these, in single channel, can't get it higher. Seems like the memory side has improved as I used to get problems with 1600MHz on the older chips.
You got the ram up to 1900?
Screen or it didn't happen. :D
Hi guys. My CPU is stable at 4GHz and can do about 4.2 with high voltage, but unacceptable for 24/7. What's the chance if I take one "random" 965 C3 it will make 4.2 full stable for 24/7 with 1.55V? The thing is that i can't go handpick the cpu and if I order one I should have big luck to get a good overclocker.
This is my newest spi 1M on air! Ambient temperature about -1°C
http://i46.tinypic.com/mku9ab.jpg
Man Cele303, you are so close to 14's on air!
I will wait for night to come, maybe -3° or -4°C will allow me to enter sub 15 on air :D
http://i50.tinypic.com/21j7toi.jpg
Dam dude thats sweet, what rams sticks you running ? micron GTR ?, wish it got that cold here :shakes:
No, my previous chips were D9GTR, Super Talent Project X 1800 C7 2.0V, they were able to reach 1720MHz 6-6-6-18 1T or 1500MHz 5-5-5-15 1T (2.2v)... These are Corsair Dominator GT 1866 C7 i7 kit 3x2GB 1.65V but I'm using only two sticks
Ahhh ok thanks, i was going to buy that kit, but its very pricey, i have the 2000 cas 8 GTS, have to see if they will go that high.
Final set of tweaks completed :)
http://img63.imageshack.us/img63/536...0mhz665867.jpg
And 3DMark06
http://img682.imageshack.us/img682/8...0mhz6653dm.jpg
Cele, u are crazy man :D, very impressive with AIR !!! Here is a few my AIR superpi with 10C in room :)
15.703s
http://img191.imageshack.us/img191/6...mhz3024mhz.png[/IMG]
0944FPMW @ -9C core temp
Boot up @ 4.54Ghz
Vcore @ 1.65V, but cpu power monitor in bios shows 1.74V:confused:..Typical M4A79T Del mobo problem with overvoltage
http://img30.imageshack.us/img30/288...nshot486ri.jpg
http://img710.imageshack.us/img710/4...eenshot488.jpg
http://img51.imageshack.us/img51/3594/screenshot490.jpg
5Ghz sinar! That's very impressive sir!
Great job FlanK3r! You are improving your ddr2 scores each day! :up: Keep up the good work! :up:
sinar, great results, what single stage do you have? What is the best SS out there at the moment? I want to buy one to have air/water/SS cpu comparisons
