nm..........
nm..........
Hmmm Me likey the HT challenge.....
Reminds me of the good old days when FX chips were way way way out of my price range :up:
I added a 17x run. I will try a 10x next. I have ram that does not like real low dividers so we'll see how it goes.
http://3800z24.info/Phenom/965/4.3-3d06-310ht.JPG
http://3800z24.info/Phenom/965/4.2-3d06-250-17x.JPG
I thought its only using the 10x and 17x multi?.........should have used that for the test
oh crap. I used 14 x not 10.. I am dumb.
well, i'll fix that soon.
I hope I included everything on the picture... got a low overall score due to my 4830, but at least htt is @ 345:
edit: sry for the double cpuz window, i forgot to switch to the memory tab..
http://img704.imageshack.us/img704/6264/54992737.png
Nice run beta.:up: What was your memory speed and timings?
thanks theoldtimer, ram was @ 1380 cl7 (1:2), the nb I dont remember, I was half asleep during testing :)
Seems this bios I updated to to get c3 compatability has killed HTT overclocking........with the 0903 I could at least go up to 295mhz.........now with this 1303 The most I can boot from the bios is 210mhz and using AMDOD the most I can get is 250.....251 locks up.
Ive tried changing memory/nb/cpu speeds and voltages to no avail over the past 3 hours.
Ive also tried on Vista and windows 7.
http://i271.photobucket.com/albums/j...1/17multi1.jpg
well here are some of my results so far :up::yepp:
ambient is 70F and this is in my closed case with xig s1283 and scythe ultra kaze @ 3000rpm
in the next few days i will go back at the 17x multi with some actual cold air, i just cant tonight. (edited with some new 17x multi scores)
all done on windows 7 64bit
got runs with 10x multi @ 300htt, 310htt, 320htt, 330htt, 340htt, 345htt (1st pic below), 349, 350, 351htt all crashed within seconds after applying in AOD (some interesting scores as i had to change nb multis and ram dividers etc between some runs)
i think i need to get it a little colder to get 250+htt on 17x multi... i did get 17x multi with 245htt
EDIT: just ran a few more with some cold air using 17x multi - got up to 255htt = 4335mhz CPU w/ 2800mhz NB (new 2nd pic below)
also notice how much the 4870x2 scores went up with more cpu speed :)
http://i70.photobucket.com/albums/i8...on2/345htt.jpg
http://i70.photobucket.com/albums/i8...5htthighnb.jpg
Nice runs man
On a side note...
Using the 10x multi I have to limit my NB to 2500mhz to keep in line with the cpu at 2500mhz and my 250mhz HTT limit
I can boot to windows with the copu at 2ghz and the nb at 2.8ghz and run 3dm06
If I try to raise the HTT to 250 and try to keep the nb around 2700-2900 the system hangs and reboots due to the fact that AMDOD doesnt like nb higher than cpu
Also If I have the cpu at 2ghz and the nb at 2.8ghz and I try to open AOD it will automatically set a higher multi to get the cpu above the NB.
just a couple notes Id like to make people aware of
Ugh....:(
I cannot compete here unless i get a bios that will allow more bus speed.
Definately a bios issue, already flashed back from bios 1003 to 0503 without result.
Wondering what others will get with this crosshair III. 345 busspeed is awesome. :up:
What voltage do you guys set for chipset?
Which is the right bios? :confused:
Thanks man, no need for asking the user, it was in the screenshot. ;)
I was stuck around 255 HTT. Upping the NB (chipset) to 1.2 (+.1v) got me up to 311 HTT stable enough to run 3D06...
Heres the SS @ 311Htt
http://i30.photobucket.com/albums/c3...3_Nomis10x.png
I think Im officially out of this AOD is not working properly.
as an example I can boot to windows at 285HTT Once in aod if I move the slider down even 1 mhz the system will freeze. Im good to 295mhz from the bios but any movement I make in aod causes a hard lock:shrug:
Titan,
This particular part of the test is not about how "good" you look while getting a result. Its just about getting a result at high HT.
Try killing all devices in bios and drop everything down.
Take a break and take another crack at it later.
Try the asus OC utility that came with your board ( if it came with one ) or try an older version of AOD.
Good luck. :up:
..omg, with busspeed i have not much chance:shrug:, my BIOS (or board) is not good for higher buspeeds, amybe 240-250 max.
This is most certainly the jam you need to play when benching like this as board death and or HD is imminent.
Plus the jam is sick
:guitar:
http://www.youtube.com/watch?v=Tpy_pYXSpPA
http://chew.ln2cooling.com/XS%20low%...reaper%202.jpg
http://chew.ln2cooling.com/XS%20low%...reaper%203.jpg
Simon your killing me with this 10 multi, chips running out of gas clock wise.
Will get the data you need in the future.
http://chew.ln2cooling.com/XS%20low%...reaper%204.jpg
Crap! I'm struggling for 300 and you're doing 400 easy as pie. :shrug:
Back at it tonight for sure. :)
