Good to know maybe they can get the new boards to have better PP, one can always hope.
Did some super pi for Pi day :) C8 2000 dominator gt's on the gigabyte 790xt ud4p, wasn't so easy getting it this fast. A lot of this rubbish :(
http://img641.imageshack.us/img641/9127/notfairq.jpg
Got it sorted tho.
http://hwbot.org/signature.img?iid=3...se&iehack=.jpg
Some 1m.
Borked my xp install for the 5th time this month :shakes: So with a proper os I think I can get under 13 second 1m hopefully :shocked:
Plenty of headroom with northbridge and tweaks etc but I just want to crack 900mhz 32m stable on this board with these timmings!
Has anyone tried Team Xtreem DDR2000 2x2GB at 6-6-6-18? Preferably on an MSI 790FX-GD70?
could be board design, could be way it interfaces cpu, could be the power delivery or how clean power is to ram causing poor clocks and them compensating by running slack to match competitors.
Nice to see your memory in action El Gappo :up: I think I've seen 924mhz with your timings for 1M with 2000C8, and good luck with 32M :up:
Few months back I did my best air 32M with Gigabyte with open window when was cold outside
http://img191.imageshack.us/img191/584/superpi32mcr.jpg
Talking about PP, this is Gigabyte with optimized XP
http://img80.imageshack.us/img80/3464/perfnumber1cr.jpg
This XP install survived almost 6 months and many chips, too bad I didn't see number of BSOD and restart times in Everest :D
I must do again the same OS optimization and compare MSI with Gigabyte with the same chip, memory and bios setup
1.70V around 1800 and 1.75V 1800+ (up to 1872)
Too bad there is no fine adjustment with my Giga, next step 1.80V is little to high for me, it would hurt my heart if something happen to memory, I use it for 1M only if tRC 11 (1888 6-6-6-18-11 1.80V), MSI bios is better with adjustments, I'll see the difference with 0.01V step between 1.70 -> 1.80V
Enjoy yourself :) You have plenty of cooling choices, I wish we are neighbors, I would join you surely :)
*chew, you said earlier in this thread that u've tested some kingston kits, and they are not in the same league with the 2000 C8 Dominators or something like that.. Are they that bad? Cause the hyperx 2133 c8 2x2gb kit (KHX2133C8D3T1K2/4GX) is, sadly, about the only kit with elpida hypers available on the market around here :(
I'm willing to spend money on 2 of those corsair sticks that go for 200$ on their site. But i'm not willing to add a lot of weight to the custom's wallets :(.. i hate this bloody country and its stupid regulations.. sorry for the offtopic remarks. Thanks a lot for the advice man, you've been giving a lot to many of us.
Has anyone tried this Kit on AMD?
Mushkin Ridgeback. 1600 6-8-6-24 @ 1.65v
http://www.newegg.com/Product/Produc...82E16820226123
My cheapo Crucial has served me quite well but I need a spare kit so I thought I'd try to buy something decent.
It's fairly new and I'm no RAM expert, but it looks pretty good to me... ;)
EDIT: One last question... :)
Does anyone think this kit may have the same IC's just with lower voltages and looser timings?
It's $30 cheaper.
http://www.newegg.com/Product/Produc...82E16820226122
Does anybody know where I can find some OCZ (ANIMAL) memory? They run real good on my rig nice and stable with tight timing. I am with you Davebert has anybody tried those Mushkins??
Well they are good in 3d as they tend to clock higher and have good throughput, in the end it takes higher clocks to beat a result so effeciency isn't there but it does beat a result.
Everything else appears sub par however, high clocks can't save it in anything 2d related.
They're ugly but I wonder how these sticks would do. 2200 CAS8 should be comparable to the $200 stick Corsair GTX yeah?
http://www.newegg.com/Product/Produc...-411-_-Product
These are interesting as well. 2200mhz CAS7.
http://img695.imageshack.us/img695/3...ageviewphp.jpg
PVV34G2000LLKB Cas8 2 x2Gb 1.65v
Paid $200usd at Newegg
1st try:
1800 8-8-8-24-32 1T 1.65v
1600 6-6-6-18-24 1T 1.65v
1333 5-5-5-15-20 1T 1.65v Passed OCCT 1hr @ stock cpu clocks, 1st test so far.
Asus M4A89GTD PRO/USB3 955C3 W7-64
3.6/2.6 stock volts although had to set mem volts for 1333/5-5-5.
Have not torture tested yet though, just running typical apps, virus scan and installing programs for new install. Will edit this post if it fails OCCT.
Edit: Can't run it too hard yet with stock cpu cooler.
2x2GB 2000MHz CAS8 Kingston HyperX
click for larger image
http://www.edgeofstability.com/image...00_6_mem_s.jpg
