Looking good xoqolatl! Can't wait to see some scores once you get rolling.
It's asus, 'nuff said.
Thanks guys :up:
Max blck was the same on two different CPUs and on different multis, so I'm assuming it's mobo limited, at least for now.
PCI-E was 110 MHz - didn't make any difference.
Max DDR2 speed - I couldn't put my ddr2 sticks in, they have some weird slots on maximus III :D Yotomeczek did DDR-2400 9-9-9-24 with this rig without much pushing. Memory is GOODRAM PRO, a Polish brand, Elpida Hyper based.
Video card is MSI GTX285 something, a non-reference design with a giant cooler with two small fans.
my mistake lol
ddr3 it is :)
good ram and it looks nice...1.65v?
did you try 112 - 115?
Thanks guys indeed the problem was the Aero Theme.
This is what I have so far:
23.023
Problem is I need 24.4K and my 4 SSD's are no match for the Acard's this guy is running.
I will need a good controler to use the cache in my favor istead of the ICH10 or some Acard's.
My problem now is on HDD - General Usage and HDD Virus Scan I'm getting 55MB/s and top 2 are above 180MB/s. Virus Scan is another one that there is no competition the numbers are huge
Great run Jor3lBR. Have you done any tweaks to try and optimize your ssd's?
there is one setting in vista/win7 that kills performance...i forgot what it is...PLEASE HELP :D
also what is is your stripe size? 128k is optimum for 4ssds
raid 0 right?
i found it :) enable performance :)
http://i24.photobucket.com/albums/c5...ty25/ddddd.jpg
I did enable the cache thru the Intel Matrix Software: http://i25.tinypic.com/zx36zr.png
In Tony's thread on the OCZ forum he lists some stuff for ssd that I tried and helped my hdd scores.
http://www.ocztechnologyforum.com/fo...ad.php?t=47212
Here's a run I did in July when I was trying to learn PC Mark 05... http://www.hwbot.org/result.do?resultId=873130
thanks loonym
i totally forgot about largesystemcache...thats a big factor there...
Thanks Loonym and Hondacity with those tips I gained a little more:
23,239
I grabbed the 3rd place on the category and gain a few more points, I still wanna aim those 27.2 points from 1st place.
I'm calling it a day and have to clear the guest room for the weekend.
Thanks again guys!
Some pics just for the laughs:
http://s566.photobucket.com/albums/ss102/Jor3llBR/
nice run...but AWESOME pics :D
i did some single card benching today....woot :) not enough yet to be 4th place @ Team.XS :D
Loonym
awesome score..what were your hd's?
My drives are supertalent ultradrive me. I love those little things and they're pretty much the cheapest in their class when it comes to speed.
i just bring home ~60pounds of dice :D
time for some prep work now...wish me luck
60lbs..hmmmm
i hope you cover your ram too with dice..insulate then rage on thru :)
good luck mk_ultra
Good luck there :up: I've had only bad luck today so far... topped my max valid and max pi with i7-870 but nothing more.
well it started really bad for me too
i broke off my cpu pot hold plate, i'm running like this for the moment, i'll try to do something temporary go on.
I've waiting for my pot to emtpy to not waste dice then to i'll resume later.
so far i tried some max valid, came 1blck short of my previous CPU. Will give it another shot, it's weird i've stopped with 2 different cpu at @ 249 and 248 maybe it's my settings idk.
hondacity
i'm too much of a :banana::banana::banana::banana::banana: to freeze my ram like that :P:
Hm.. having some trouble here.. I thought I could top my PCMark Score but somehow I can't. Got a system with w3520, 2x GTX 280, and 2x Supertalent Ultradrives here. Somehow I thought that would beat my last score with the 1 SSD. It doesn't. 18200 with the CPU at 4,3 (stupid GB board freezes at post >205...). Do I need moar CPU, moar GPU, or what. SSD tweaks all in place. Vista 64.
Sounds like your raid controller is holding you back?
J micron by any chance?
did you compared detailed score to see which one is low? gpu or hdd
supertalent too..on ichr controller....raido
gbx58extreme tops at 200-206 bclk x21 is only above 4.2ghz
i can't beat my single 32gb gx..run :|
i'm still figuring out what i did to get 200MBps(1x drive) on hdtune...
with raid0 i get 115MBps(2xdrives) on hdtune
first time with raid0 :D
Huh? So you are stuck on low BCLK too?
WTF..
Your Raid 0 performance should be way better tho. I measured something like 450MB/s read from my array on the GB.
