Is the Sapphire 4890 Vapor-X 870mhz gpu a reference card?
pictures on the phone. bluetoth, I could not transfer defective. work is not finished yet, gets very hot.
now that the fastest
http://img81.imageshack.us/img81/1482/1430mhz1.jpg
Wow! :down:
EXPANDER, will show the hard mode ;)? or you will show 3256436256 screens with high mhz and no benchmarks :D
I can push my gpu in 2d that high too. Come on, show us some scores with that frequency:yepp:
bin size it's the same , the card is the blue sapphire reference, same pcb or the red but i cannot flash the bios said SSID mismatched.... what the hell ?? how can i do this flash ?
EDIT: problem solved with -f command :D
You can check what pixel fillrate and texture fillrate are at 1250MHz : http://www.xtremesystems.org/forums/...&postcount=225
(for lazy ones: 20GP/s and 50GT/s)
Expander.. this is not the first time you post some paint screens. Why do you need to put those white bars in there. Something under NDA :D
Please, don't do it anymore. Show us some full benchmarks and pictures of modifications. I am getting really tired of your play here :shakes:
Anyone here with some real results?
others to share hardmode.
4890 Wampire Hard Mod, currently in operation.
Faking FTL... Nicely spotted, guys.
:shakes:
:down:
pixel/texture fillrate me too does not appear!
gpuz or windows 7 64 bit,
error source!
Yes, that is typical situation. If your card can do 1200MHz+ with original bios, you will not need this fixed one. It will not help you at all.
Funny, that this thread is mostly populated by people with "good" cards. All the guys who got gain from this fix are not posting anything. Well, that is the way it goes :D
Well, i'm not a hard overclocker but even then i'd love to see how far my watercooled Sapphire goes but the thing is... i don't really know how to extend the 1000MHz limit in CCC for overclocking, pardon me the noobness :rolleyes::D
If someone could clarify that for me, i'd try it.
Does anyone know if its possible to increase voltage on the sapphire 4890 vapor-x through software? Ive read that it might not be possible.. Im getting my card soon so i hope its possible.
If its not, is it possible to reflash bios and set higher voltage that way?
I think to use software to adjust over 1.4+ u need to move 2 resistors:
http://a.imagehost.org/0234/85.jpg
The 2 pins should be 1,1 , I think they are 0, 0 now, i think the 2 corresponding pull-low resistors moved down becomes pull-high then prolly more volts can be used by software.
@ LardArse
correctly identified, required try.
[ Ovp ] mode is required.
