Just ordered the UD3R and superbiiz confirmed all they have is revision 1.6 boards.
So, will I gain anything from the special BIOS posted earlier, or will the normal get me around 230BCLK?
I havent modded my board yet, but it can do 228 with pci 102. With ioh clock skew at 650 max was 226, increasing it to 750 got me to 228. Anyone else using this much ioh clock skew ?
(PM sent to hicookie)......does this hard mod work on ex58-ud3r "rev 1.0" my board wont stay stable above 200mhz bclk...i have a 920 D0
I guess superbiiz are liars. It came and is rev 1.0, and not only that, the box is beat up. Looks used, or at the very least, a refurb or returned.
your doing better then me i can boot up @ 210mhz bclk x20 multi "21x with turbo enabled"...but nothings stable above 200mhz (4.2ghz)....so im still waiting on hicookie to send me hard mod directions and bios..hopefully i have the luck others are having with the mod :) id be thrilled to get 4.4ghz stable on my 920 D0 to feed the HD5850 i plan to get soon when overclocked editions with better heat sinks hit the market and drivers mature a little...not to mention no one has one in stock :rofl:
Still can get vcore lower, at 1.36 in BIOS, about 1.33 actual. VTT wont go under 1.395 though. Ive gotten 4.3HT stable as well, but Im waiting for my ram fan to come so I can get my ram over 2050Mhz, as they wont do it at 1.65V.
http://i38.tinypic.com/1zwdwdt.jpg
Hi all......
remove only resistor and not resolder my mainboard ud5 x58 work or not.????????
THX.....
Sorry for my bad english....:(
http://pic.ipicture.ru/uploads/091018/1VxnSv5ORV.jpg
Many thanks, really work. Today has made it, 238 on the bus mother could take, before only 228 and all.
Is that the same mod for the UD3R revision 1?
hicookie please check your PM. thanks
Is that mod possible without any risks, I mean for normal using the board after benching?
Does it influence anything?
Is anybody here, who could explain the mod?
Sure. But what do you mean with explain? I think the above images speak for themself :shrug:
How did you push the solder out and how in?
