Man i start to believe that your board is one of a kind....
Don't take the m3a79....:D
Ok first retail result from finland, you can buy 940 BE now :P
voltage unknown yet, user said he's tweaking more so stay tuned ill try to catch all of his results.
Phenom II 940 @ 3.8ghz and radeon 2900 pro
3Dmark 06
http://service.futuremark.com/result...eResultType=14
http://img185.imageshack.us/img185/5...bench32gf7.png
The Stock CPU---- NB/HT@2000
http://img201.imageshack.us/img201/8...iistockuy3.png
Any of you guys care to report temps @ stock Vcore?
Sure....H20 here
http://img370.imageshack.us/img370/41/stocktempsze8.png
Thanks HodaGuy;) I recon that High End Air Cooler will be about the same at Idle as Water.
Ive has this chip up to 1.55 so far under load was about 44....Room temp right now is 22
HondaGuy: Thank you
BenchZowner, can you run x264 benchmark with a newer x264 version?
The included are too ancient :P (8 months old the newer).
I've adjusted the bat file (and the vbs file to launch the new bat) to run one of the latest (if not the last, I've not checked today), r1069. The only issue is that fps results don't write to the rtf file and I can't figured out why :shrug: Anyways, you can see the fps from the ms-dos window ;)
The settings are the unmodified Standalone-Blu-ray_fast profile from Megui (only adjusted the bitrate to 3959 from 8000, just like the bitrate used with original x264 benchmark, and I guess this standalone profile is the equivalent to the one used with original bench).
You have these files attached inside a zip.
And here the x264 r1069 http://rapidshare.com/files/17938606...-1069.rar.html
Thanks.
Hi hi, I guess he used air cooling for that bench :)
Because at 3.8GHz with water cooling, the temps were similiar with 3GHz :rolleyes:
http://img117.imageshack.us/img117/9...iitempssh9.png
http://www.xtremesystems.org/forums/...&postcount=250
In Vista, yes, but this was XP (according to Futuremark).
It's a little lower than my Q9450@3,7 - 5885(compare)
Still, I am more than convinced over PHII. This is a "must buy". :)
When the room temperature is around 22*C(as he said) what delta T do you want to make the water? 0 degrees? :)5-6* are something normal, the load temps are more interesting than the idle :).
Your card is much faster than 2900Pro, so the CPU score is higher because of it, not because the CPU itself.
P.S. I hate you, all that have already got their Denebs :D
Updated my results.
Phenom I
http://service.futuremark.com/compare?3dm06=9391970
Phenom 2
http://service.futuremark.com/compare?3dm06=9484910
All same except prosessor.
