If you insist Trini...
Once sideport is needed and enabled, then it will have its architectural advantages, yes? I know that has little to do with 2 vs 1pcb but...
Doesn't make any sense to launch another high-end single gpu so soon. With GTX295, the GT300 would be kind of useless.. Especially in that timeframe.
Then again, nVidia already made that mistake, with GTX280..
Yeah you're right, if you're looking at after-market cooling solutions the single-PCB design will be easier to work with. But we were talking about the relative technical (in)elegance of the two approaches. Neither provides any tangible advantage to scalability or performance of multi-GPU.
And jas, sideport was promising on the X2 but it turned out just to be another high-bandwidth link. And when they realized that PCIE 2.0 provided enough bandwidth already sideport became redundant and was disabled. There needs to be more integration before multi-GPU moves to the next level. It's a moving target though since on-die bandwidth and processing needs will continue to outstrip any sort of inter-die communication or data-sharing approach.
dont know if anyone saw this yet from expreview
http://en.expreview.com/2008/12/16/g...html#more-1646
shows some real potential
review coming tomorrow 18th of December?
http://www.guru3d.com/news/tomorrow-18-december-/
You guys view the sideport as this holy grail of performance unlocking, which is always just over the horizon.
The sideport is for facilitating faster inter-gpu transfers, so there's less stalling when a lot of resource transfers need to occur often. Most games have profiles created to stop these transfers anyway, so the hardware implementation is only really useful in a generalized case without a profile. It doesn't necessarily speed anything up when compared to a game with proper CF profile support where transfers are already minimal.
Deanz, that link doesnt work
YES, reviews will be tommorow ... in limited numbers.
and what does that mean 'limited numbers'
Limited websites, hand picked i assume...people they trust under NDA etc.
Review will be only on few magazines ... wait for tommorow
Will be out for sale on the fisrst day of CES and the MSRP will be around 500€
im guessing the cards will be well overpriced worth the money ? hmmmmm i will hold tight think its guna be a stormy ride this one lol
Found this picture, shows more than the picture from guru3D
Looks good :yepp:
PRJ
Any reliable source for this? 500€ sounds about what I would expect though, like $599 in USD MSRP I would guess. Of course europe's high taxes and low availability at launch will probably push them at least to 550 EUR, but let's just hope NV won't pull another 8800 Ultra as far as price and availability goes. :p:
