is there any improvements on temp monitoring for multi processor systems?, IIRC, the version I was using on my quad quad (probably mid 3, late2..can't remember which one) would only monitor one set of cores
OCCT 4.0.0 Beta 5
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.b05.zip
OCCT PT 4.0.0.b05 OUT !
Changelog (in english as people are copy/pasting it from here) :
Graphs are now in a separate window
The graph window is resizeable. if it is in float mode, it is maximizable also.
You will now be asked to include comments in your bug report if you find an error
Linpack doesn't crash in automatic mode
Linpack libraries updated
The CPU time taken for updating the graphs is related to the graph size, be warned !
And a huge load of bugs.
Enjoy !
Source
OCCT 4.0.0 Beta 6
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.b06.zip
* GraphTheme file created : please customize it and send it to me... i do hope i'll receive at least some themes...
* Font size is now linked to the window size for monitoring. Up to some extent, of course (i don't want REALLY big fonts displayed).
* Linpack updated - works on AMD CPUs now
* Test statuses revamped - please do careful review of all tests
* Tests are now stored within the exe instead of the bin folder. This will avoid the security warning on Windows XP
* Donations are now possible directly from the main interface, and a popup asks for donations, only at the first launch
OCCT 4.0.0 Beta 7
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.b07.zip
Does not crash anymore on some computers (a problem with the video card detection)
The file graphtheme.csv is available in the release
OCCT 4.0.0 Beta 8
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.b08.zip
Removed graphic card name detection as it seemed to cause trouble on some computers
Fixed a bug where CPU:OCCT didn't load all the cores. It works fine now.
Improved the help text in the main form. Not fully done though.
Removed the unused file linecolor.csv
hmm Beta 6 through 8 seems to not work for me...OCCT just crashes. :(
OCCT 4.0.0 Beta 9
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.b09.zip
Most of the font are now internal. It isn't true yet for the monitoring form and the graph form. This was left "as is" as the priority bug was important for me. Will be completed on b10. Only important if your computer doesn't have verdana installed.
Priority is now properly set for both main app and cpu:occt test (ldlc4 : rejoice !)
OCCT doesn't crash anymore when Windows's performance counters are not available
HT detection algorithm improved - results ?
cpu:occt now only checks for memory once, instead of twice (should be more than enough)
Known bugs :
plugin configuration like aida not saved. Couldn't fix that in time, sorry.
thanks stasio for the update! :up: beta 9 doesn't crash anymore on loading BUT CPU usage is set to always 0%
OCCT 4.0.0 Beta 10
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.b10.exe
First version of the installer. Supports DirectX update and Framework .net 2.0 auto setup. Try it out !
First version of the localized UI (french only). If the OS is in FR, french will be auto loaded.
UI Optimization. Much faster when changing tabs, for instance.
Graphs generated at the end of a test are now complete. Its folder opens up as well (once per session)
New splash screen with progress information (well, a string saying what it is currently doing). ~tmp001.tmp gone.
Known bugs : still the annoying config loss on aida. Could not debug it yet.
OCCT 4.0.0 Beta 11
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.b11.exe
Fixed a critical bug where OCCT crashed if you had two sensors sharing the same name.
OCCT 4.0.0 Beta 12
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.b12.exe
Second idle period now properly handled
The monitoring form size does not get too low when going below the taskbar
Monitoring style and position is now handled directly by buttons
Aida64 settings (and others) when auto launched now properly stored
Monitoring tables and graph should not overlap, and should be a bit better looking
A lot of small bugfixes
Voltages are all wrong with my P5E motherboard (X38), shows 12V as being 8V, etc
HWMonitor Pro seems to have the same problem where Aida64 doesn't.
Attachment 117592
OCCT 4.0.0 Beta 14
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.b14.zip
Lots of bugfixes
SplashScreen now correctly gives focus to the main window
Built-in plugin settings properly stored
Font size detection improved on monitoring window
Fixed minimum size for monitoring window
OCCT 4.0.0 Beta 15
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.b15.zip
The horizontal scrollbar doesn't appear in the monitoring options anymore
Minimize to tray function fixed
the options are now correctly reenabled when a test is either done or cancelled
OCCT, my fav oc software been using it for a while. Great proggy guys. I have 3.1 installed, gonna check out the new 4.0 beta u guys realeased.
OCCT 4.0.0 Beta 16
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.b16.zip
OCCT properly handles sensors sharing identical names
OCCT won't crash when trying to delete temps files (occured sometimes)
OCCT 4.0.0 RC1
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.RC1.exe
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.RC1.zip
New monitoring engine with sandybridge support - try it out
Options now properly re-enables when exiting a test
Monitoring is now on the right-hand side by default
Graph name ending with 0 fixed (e.g. core #0 )
Removed the zip button from now (wanting to improve that part with mail)
minor bugfixes
OCCT 4.0.0 RC2
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.RC2.exe
http://www.ocbase.com/OpenBeta/OCCTPT4.0.0.RC2.zip
Monitoring window position should now be properly saved
Monitoring window won't be set to left when opening/closing the options now
The CPU frequency is updated every second in the main GUI
OCCT 4.0.0 Final
http://www.ocbase.com/download/OCCTPT4.0.0.exe
http://www.ocbase.com/download/OCCTPT4.0.0.zip
Changelog (Since 3.1.0) :
MAIN
Brand new interface with real-time graphs !
Infinite mode is now used as default
In automatic mode, the IDLE periods are fully customizables
GPU:Memtest isn't available in this release (It is scheduled for complete revamp soon)
Settings simplified
Screenshot button (PNG format)
CPU:OCCT
No limit to the number of cores supported
CPU:LINPACK
Updated to support the newest Intel instructions
GPU:3D
Waiting also for complete revamp (already started - will be DirectX10 based (will run on a vanilla seven and vista). I'm studying DirectX11 (waiting for a card that supports it in fact)
MONITORING
Huge update to the monitoring and system information engine (supports Sandy Bridge and Bulldozer)
Fully customizable real-time graphs (look in OCCT's settings)
Minimum and maximum alert values can be set for every sensor !
INSTALLER
Will install .net framework 2.0 if not available
Updates DirectX9 if not up-to-date
TRANSLATIONS
New engine for translating OCCT - XML Based
Older translations had to be dropped - sorry
Instructions on how to translate OCCT will come soon...
I haven't tried it yet, but Great Work anyway!!!!!!!!!!!!!!
omfg thanks for 4.00 FINAL !!!!
"Voltages are all wrong with my P5E motherboard (X38), shows 12V as being 8V, etc"
same here 12V as 9.14v hehe...
OCCT 4.1.0 Beta 1
http://www.ocbase.com/OpenBeta/OCCTPT4.1.0.b01.zip
First early release of GPU:3D DirectX10
Complete rewrite, faster algorithm, much better error checking (should be).
Error check mode is restricted, FOR NOW, to 512x512 windowed
While you can specify a refresh rate, DX10 doesn't really allow me to use it - will be disabled later
Monitoring options will come later
GPu/3D tab still requires DX9 to be installed to be enabled (i didn't implement DX10 detection algorithm yet).
OCCT 4.1.0 Beta 2
http://www.ocbase.com/OpenBeta/OCCTPT4.1.0.b02.zip
GPU:3D DX10 updated - does not crashes on AMD GPUs when detecting errors
Monitoring implemented
Fully integrated with the GUI
Added polish translation
