Ive just heard that the AMD 3200+ droped from $417 to $278 !!
So it will be the best for me to buy a 3200+ :)
SW --> Ej er du nu også her ?! :D
2 WRs :
403.88FSB with MemoryFSanMax PC3200 BH-5 256MB / DDR266 / CL2.5-2-5-2-8
VDDR : 3.39v
VIO : 3.73v
CPUFAthlon 64 3200+ 0334MPMW
JAP guy (NEWBEETLE) DETECTED :smileysex
http://homepage2.nifty.com/NewBeetle/img022.gif
and
Wow 43sec in pifast is amazing :)
Running 1:1 ? :)
cpulloverclock - Let us know how long that A64 lasts on 3.7v...
AN50r
3200+@240x10@1.65 Just AIR
Died, after 2 days.
Just the board died?Quote:
Originally posted by gabbax
AN50r
Died, after 2 days.
Well, to be hounest(spell:)) I do not know, it refused to start, so i RMA it to the store, i hope il get some new stuff next week:)
And i did test all i could do, just dead, wont boot at all...(i think the CPU died,and the motherboard still alive)
Yepp, the "buffert" or Full load temps are Amazing with DIce, i did test it on my P4, and it just rice 1-2!! deg under SuperPi in 4100...
http://www.watercooler.com.br/copyman-modshop.jpg
While my gigabyte doesn't arrive and my r404a 1,1\4hp 890w@-35c chiller not this finished, oh they are my results full rock solid and stock air cooled
system
asus k8v deluxe " argh " bios 14
a 64 3200+ @ 2470mhz 1,75v stock cooling
xms 3500 2x256 mb 3,25v 2\1 247Mhz 2 2 2 5 11 16
9800np san 3,3 ns @ 9800pro 535gpu (air cooled) 384 mem
(one among 23 different bios of 9800pro's that I got to do to rotate solid to 247mhz " 82mhz agp ")
25.781kmarks
http://service.futuremark.com/compare?2k1=7425759
In one day with win2000 and rotating the tests to punctuate, and increasing a little the over of the videobord hopes to kick 26.6 26.8 totally air cooled with to 9800 np 3,3ns san and that horrible motherbord...
I find good results tends in view the system of refrigeration and the used mothebord, and mainly gotten with air cpu (stock) and gpu.
I thanks the friends a lot (mickey ,major, OPP, macci, Bownman, mister ice and among others) that always helped me in a lot of doubts them and they never stop answering a tread or mp
You are incredible
If somebody has interest in information on my vmods topic
http://www.forumpcs.com.br/viewtopic...a027281d7b3a93
or super chillers
http://www.phase-change.com/phpBB2/v...?p=10084#10084
cya
in time...
i got, after changing 23 bios of 9800pro's, to find one the to work more than 82mhz in the agp
I think with it you can play a little more with the 9800pro without collapse of the agp with via bords
I have some 12x 9800pro original home, but I didn't have time of trying this bios in it.
none of those 12 9800pro nor it mines 9800xt it was besides passing from 71 to 74 Mhz in the agp
a lot of game for today the night
who wants to try this bios in your 9800pro´s to rotate in high values of agp, only to order me a mp ok
I just read this:
http://www.theinquirer.net/?article=13525
I hope it's true
pretty long, as long as you don't use Shuttle mobo.Quote:
2500mhz air cooled
CAAMC 0339WPMW
9446548130306
http://eshbach.s5.com/2500.jpg
Here is mine so far
3.0 GHZ :D
I'm Getting a CAAMC 0349 RPMW. I have heard people score bad with this core :'( People here who have seen it run good clocks ?
I was unable to run 2400MHz stable with Vcore 1.6 ~2.0V with that stepping code. The temps where good (38C).Quote:
Originally posted by Astennu
3.0 GHZ :D
I think my K8N pro is holding me back, i dont know.
If i was you, give it a try.
fine stuff. can't wait to see what happens with 9 microns. how many chips you had so far jason? whats your take on the best steppings?
3012 1.95 ADA3200AEP5AP Abit KV8-MAX3 Zalman CNPS7000A-ALCU 21567
someone from the cpudatabase got 3.01ghz on abit Kv8-max3.....
1.95Vcore
and also it seems that amd made some tweaks on the a64 3400+
people nearin' exceedin' 3ghz
soccrstar - you get 3ghz on air??? :slobber:
how stable is that
ohh daz HSF? :confused:Quote:
how stable is that
didnt kn0
s0rrie
i ordered a athlon 64 3200+ wit abit K8v-max3 motherboard
and OCZ PC4000 (ddr500) gold edition 2x512mb DDR memory
and antec 550 trupower power supply
anyone with k8v-max3? how is it? good? no multi changed? tried upgradin bios to see if they added that feature?
(currently got p4 2.66@3ghz, gigabyte 8KNXP (canterwood), 4x256mb cas2.5 memory.)
i get 1min 10sec in superpi 1mb
[edit]
is it worth it to watercool a athlon64 northbridge?
I think he means he saw someone with this entry in the database.
I find 3Ghz on air hard to believe, any more proof ?
Regards
Andy
seems nearly impossible to me to reach 3ghz on air, especially while putting 1.95v in it. . you just couldnt cool it enoughQuote:
1.95Vcore
just IMO anyway
how are you people gettin' past the agp not bein' locked?
my motherboard i can change the agp clock by itself (non-amd)
to c the tolerance on my r9500 to prepare for my athlon64 comin' diz week.
and it wont post @ 74.
how much of a OC from a 64 3200+ would i have b4 the agp reaches that bus speed?
soccrstar - nforce3 chipsets have locked agp bus. often the pci bus is unlocked though.
man someone had recommended me the abit K8v-max3
now i wont go pass like 210fsb becuz of my radeon9500. it cries even b4 it even reaches 74mhz agp freq. on nother board.
