nice work giorgio, this comp was alot of fun,
anytime i can win prizes for strapping a tek9 to ram, im in!
Shahryar, you just didnt ... 900?
900MHz dual channel :shocked:
amazing ......DDR2 1800 :up::up::up::up::up:
OMG my coffee came out of my nose when i saw this! OMG... and i mean OMG
I think time closed now for update :D:D.....damm my backup corrupt so I cant update last score ....:(:(:(:(
congartes DDR2-1800 be brocken, the competition will close after 11hours
its end by USA time, if you not update it , watch your time :D
Oh sweet, hopefully we'll see one last push :D
If your score has been rejected , don't worry about that
the score will be valid if your not using a hack software,
i will check every score, thanks for Franck fixed CPUz validation.:)
I have been to watch rugby match , ITALY-IRELAND ( 6 nation championship), we loose 38 - 9 :(
So we have still time to update ? still 5 hours ?
Sucks that I have the only UK entry. 2nd highest UD3 vanilla result though-Shpin Juriy is using a -P and i've not checked all the -P and -R submitted results for Vanillas
finally I'm third of the europe ^^ :D I'm happy!
Crucial rocks :eek:
Congratulations for the Winners!
I will see everybody in GOOC If spanish have a qualification... :mad:
its curious that Barani Shahryar and Karimkhani Ali, both from iran and in the same benching team, use identical unusual ram timings and graphics cards on both their runs...
probably just co-incidence though ;)
congratulations Barani on passing the 900mhz barrier
For me the strange part is that they're both relatively unknown, but anyway :)
Hey youngpro, after the 890 MHz run, were your sticks beached as? :D :p:
dude before i even put the sticks into the ud3 they can hardly boot, because of being trashed on biostar board, now, sometimes they boot, sometimes i had to power on off a dozen times before they start ;)
BEACHED IS
sure, ill load the board up later and grab you some bios settings,
i just give 2.9v to ram, more than that and i dont see performance improvement... im running ln2 on ram at -140 and nb at -90, with high vmch at 1.85-1.9ish
i see ram performance decrese but ram speed increase by playing with registers is fed14030..
s/so/no special settings in bios, just making things very loose, i find trrd impact ram mhz quite a bit... 7/8 multiplier also seems better for me than 6.. but i cant see any change in key mchbar registers that would indicate it is effecting ram performance,
at the end of the day giorgio i think this competition is a tiny bit of skill and a whole lot of luck ;)
welldone james that is really an amazing score, wickeD!
i'll take some pictures from board and vDIMM mod . special thanks to hazzan for his help . :up:
Conggratzzz FTW :clap: :up:
... OMG DDR2 1800...:shocked:
Shahryar
Surprisingly :up:, congratulations, memory alive?
hicookie
I Shpin Juriy , 14-th position, will there be separately reviewed my results with slats 2 * 2GB, I tried hard :) , and dry ice 1545 5-5-5-15 http://valid.canardpc.com/show_oc.php?id=468849
http://s52.radikal.ru/i137/0902/97/6c766805491ct.jpg
and nitrogen 1608 5-5-5-15 2.6v http://valid.canardpc.com/show_oc.php?id=494227
http://s59.radikal.ru/i164/0902/39/558221938098t.jpg
http://s40.radikal.ru/i087/0902/a7/4a1d2ce1e5b7t.jpg
UD3 and UD3P shown itself equally :shrug:
@Shahryar:
Great Results there. 900Mhz :eek2:
@Highherzt:Great Results on that 2x2 Kit, too. :clap: I Really love your Ram-Pot! :yepp:
How much Voltage did you guys put on the ram while running it with LN2?
