63% is 0.630x, 67% is 0.67x or perhaps 0.667x rounded up. You could safely give that cpu 1.4v bios, even 1.42v bios, and 1.3v Vtt, and it may do 3.4GHz on that. Set the cpu so it is a little unstable (fails orthos/prime95 in a few minutes everytime) and adjust the GTL to 0.667x and see if it increases the fail time. If it helps, drop the cpu back to a known stable setting and the GTL adjustment may help you reduce the vcore 1 notch or more. You have to experiment, as I have said a few times now, and find you cpu's optimal GTL Ref setting for the FSB, clock and Vtt you are using.
