Originally Posted by
redmodel
Finally put mine together. A few issues.
I am having the exact same issue as I did with the DSEB-DG board. Testing with two different brands of 667mhz FB-DIMMs, Prime95 will crash using high FFTs (above 2500). But it didn't do it with one piece of MacPro 800mhz ram by Hynix.
Does anyone else mind testing this? I'm interested in knowing if people with 667mhz ram is getting the same issue, and if people with 800mhz is not.
I don't understand why it's doing it, i am use e5450 cpus, which should be using the 667mhz ram anyways. but I want to overclock it to 3.6ghz, and I planned on getting 800mhz ram either way.
Other issue is with configuring the Marvell Network drivers to do link agregation. That is what was nice about the DSEB-DG. It had 4x intel Pro Network Ports. Zero issues. The Marvell works fine as a single link. But trying to team them up has been causing a lot of problems, to a point where I can't even get a proper connection anymore, even on a single link. I don't have any slots left either to get an intel network card :(
Third Issue, my eSATA drives freezes up the computer whenever I have it plugged in to the Jmicron port. I remember seeing this before on another build, and at the moment I don't remember how I fixed it. I have to look into it more. Just wondering if anyone has noticed this?
The other issue is changing the SATA IDE to AHCI drivers in Windows after install. This trick used to be easy on other boards, but I get iastor.sys crashes now whenever I do it. oh well.
