Karwa, it'd be best if you flashed ASUS card with Sapphire's bios, it's in newer version (071) and lets you clock above 862MHz. They both use the same PCB and memory (I checked) and Sapphire bios works on ASUS (I checked, too)
Here's Sapphire bios modded to 1.327V and with 2D clocks disabled:
http://profide.eu/files/karwa.zip
I have measured power consumption before and after flashing, and disabling 2D clocks does nothing. Power consumption is still ~230-240W when cards are idle (cpu loaded).
Powodzenia z flaszowaniem :up:
