They was close...only 50% wrong... :rofl:
CnQ is buged, disable it for bench people.
You lost a lot of power with enabled, the cpu stay at 1.1ghz on single thread.
Agena has 10-15% faster IPC from a kentfield
AT numbers for 2P comparison:
Originally Posted by AT
Considering that AMD prices this Opteron 2350 under the Xeon 5345, AMD has an attractive price/performance offering for most applications. The only exception is a chess engine and highly optimized Intel binaries. Although our testing is not finished yet, there is very little doubt that AMD's newest chip is very energy efficient. Add to that the fact that the AMD platform is not burdened with the extra power consumption of FB-DIMMs, and it is clear that the third generation of Opterons will lead in the performance/watt area for a few months. When you are looking for the highest performance however, Intel has still a solid advantage with it's 3 GHz Xeon x5365
The future looks very interesting with the 45nm Xeon Harpertown and a 2.5GHz AMD quad-core in the next quarter. AMD hasn't clearly hit a homerun this time, but at least they're playing in the same ballpark.
Just a shame they disabled hardware prefetching and forgot to list the disk systems used. Specially when most of them are heavy disk I/O based.
Nice try, no saviour.
Also doing scaling calculation is not the right way. Specially since it looks like they asume 100% scaling..and thats never true.
If someone tells you something, swears it's the truth, then later is proven wrong, then what's that saying about them? One of two things; they just didn't know any better or they were trying to willfully deceive people.
IMHO I believe AMD was being deceitful to keep their share prices up and avoid panic.
Ah lol,now even Anand is no good :rolleyes:
First ,you should read up,the hardware prefetching is disabled since it is recommended by intel as it was found that it negatively affects the performance (hence they disabled it ,duh..)
Second,yeah,now disks are the problem.Right.It is logical that Intel must have provided Anandtech with the worst possible hard drive setup in their systems,since they knew they would only be compared to the latest AMD's quad core based server :rolleyes:
As for scaling,they have numbers for 2Ghz AMD 2P system and 2.33Ghz 2P intel system.No brainer.It could only get worse for intel since Clowertowns doesn't scale linearly with freq.(fsb bottleneck).And the lowest number for K10 in the table is 1.8Ghz,so it was pretty much constant(they didn't have to presume scaling up for it since it was faster clock/clock in 2P most of the time).
I think you are dreaming again. Also if you ever bought an OEM server you would know its on per default for the same reason.
You do know much big difference there can be and is on servers diskssystem, right? No..I guess so.
Again you asume scaling is linear. Yet it aint. They could have used E5335, yet they didnt.
So you are even counterargueing youself? Since the result is based on a 2.33Ghz and not a 2Ghz? Bravo...bravo!Quote:
You have been wrong since day one on K10, and you still are.
Well, that particular review was junk given the choice of benchmarks which was unrepresentative of server applications.
It's also pretty amazing that two months after the launch and AMD still hasn't been able to release a single official score for important enterprise benchmarks like TPC-C, SPECjbb2005 or SAP-SD. AMD's silence says everything you need to know about Barcelona's lack of performance.
No they didn't they said in; "across a wide variety of workloads". What and where I ask? I saw NOTHING of the sort LOL!
http://www.news.com/AMD-Go-to-Barcel...3-6152645.html
That was parroted here by many on the Green team and asked loudly, "surely AMD wouldn't lie that much?" Ask Informal? The whole epilogue was to insert FUD and have shoppers wait or delay buying from Intel when AMD knew they didn't have a damned thing.Quote:
When it comes to quad-core chips, good things come to those who wait, Advanced Micro Devices believes.
After years breathing AMD's dust, Intel beat its rival to the punch by releasing its quad-core Xeon 5300 "Clovertown" processor for servers in November. But AMD's "Barcelona" quad-core chip, due to arrive midway through 2007, will be a significant notch faster than the Clovertown chips expected to be on the market at that time, said Randy Allen, AMD's corporate vice president for server and workstation products.
"We expect across a wide variety of workloads for Barcelona to outperform Clovertown by 40 percent," Allen said. The quad-core chip also will outperform AMD's current dual-core Opterons on "floating point" mathematical calculations by a factor of 3.6 at the same clock rate, he said
DO you realize the shrug emoticon you use very frequently at the end of your statements implies you don't know for sure what you're talking about? It confuses me so much as to if you're asking something, guessing something based on anecdotes or trying to affirm a fact. What is it supposed to mean for you?
A couple of sites made note that AMD would need to be ahead of Intel 200 MHz or so to achieve parity .. this is a bit off as the relative % compared to IPC is lower at higher clocks. For AMD to be even with a 3.0 GHz Yorksfield, they would need about 3.3 or slightly higher bin. This is not likely going to happen on their 65 nm process.
Well, AMD worded their 40% statement very carefully, at the time they made their claim, the mean 40% faster using SPEC2006FP_rates. They did not clarify if they meant clock for clock and such... they also stated in a wide range of applications, and the SPEC2006FP bench has 17 different code bases in it's suite, so one could argue that is a wide range.
Where they missed was their clock speed estimate, 2.0 GHz launch speed is significantly slower than what they planned and they had to revise their expectation downward as a result, recall Hector Ruiz downplaying the product.
Jack
Anyone else think AMD just got this into the market so that its out there so they can start working on the 45nm process instead of trying to tweak this thing?
