Originally Posted by
SynGroW
Transaction boost is setting the boards Performance Level.
Transaction boost isn't always setting directly the same PL with the 3 options it has. The PL differs with the divider you're using. When running 5:6 for example, transaction boost = 1 results in PL 8 (according to Memset), transaction boost = AUTO results in PL 10.
When you put transaction boost at 2 the board will run PL 7 or even 6 and for that reason, it won't work.
But when running 2:3 divider and transaction boost = 1, the PL is 10 for example and than transaction boost 2 will work.
The board relaxes the PL when you run a "higher" divider and you can re-adjust it with transaction booster.
