here is my e2180 100% oc (water cooled, ambient=14C)
system: ip35-e, 2gigs a-data vitesta ee, x1950xt
http://img455.imageshack.us/img455/7292/pi403x10oc8.jpg
real vcore dunno :shrug: as I don't know the correct measure point on the board
but vcore in bios was set to 1.725V
I know this might sound very high, but the temps were pretty ok, and the chip responds well to increased voltages. And I only needed it for a few minutes. Well, so far, the cpu is still alive :D
Still, 1.7v is an :eek:ing thought. Then again, these are $99 chips. Thinking of getting one to stand in for my quad (sell X3210, wait on Yorkfield), and pushing it till then - polished lid and all.
Her is my E2160 chip, hits the FSB wall at ca. 375-380MHz (doesn`t matter what I throw at it on Voltage on chipset or anything else and lower multiplier doesn`t help).
http://stud.aitel.hist.no/~arvehan/t...60/mem_okt.JPG
Stock cooler, and 1.40V in BIOS. Mainboard is a Gigabyte DS3 with P35 chipset, memory is Kingston PC4200 CL4 value. Not done tweaking memory timings and speed at all yet, 1.8V on memory goes up to 460MHz at a little better timings shown on this picture. :)
E2140 + Vapo LS + P5K3 + Cellshock DDR3-1800, weird but true :)
http://www.xtremesystems.org/forums/...&postcount=131
just had my e2180 (m0)
+ Gigabyte P35-DS3L
TR Ultra 120 eXtreme
533MHz crappy ram
i'll play around with it and post my results later on :D
Guys, I have exhausted all options and might need a hand here.
MB: Asus P5K SE
CPU: E2160
Ram: Random DDR2-667's
Cooling: Bigwater 745.
I can get 371Mhz FSB full OCCT stable, everything's fine @ 1.575v, but when I try to push it to 372Mhz, it just refuses to boot. I have tried dropping my multiplier from 9x to 8x but it does not help at all. Upping the voltage even higher does not help.
I have tried the BSEL mod, surely enough it boots up at a default 2.4Ghz now, but the situation has not changed.
Is there any other way getting past this wall? I can boot with 333FSB @ stock voltage but BSEL 333 failed to boot (it booted once @ 3.01Ghz then it won't boot again). I'm sure BSEL 266 (which i have now) will at least help somehow? But it has not.
I have lowered the FSB all the way down and ran the FSB:RAM ratio to 5:6, the Ram will happily run at 400Mhz no problem, so I do not think the RAM is at fault.
Any help reguarding jumping this Great wall of FSB would be appreciated, thanks.
http://valid.x86-secret.com/show_oc.php?id=263002
Note that is cooled by intel stock alu and arctic qeramique
Seems to top at about 3300MHz @ 1.518v (330x10)
http://img139.imageshack.us/img139/2...x32mfx6.th.jpg
3400 is unstable even with 1.550v
The bus is not an issue here, i tried lowering to 9x the multi and i managed to get 340 FSB stable (didn't try higher than this).
It's not a RAM problem neither, cause they should be fairly stable at under ddr2-667 speeds (same chips of crucial DDR2 667 kit).
I think it's just a cpu problem; i could pump 1.6v in it and i'll get 3400 2x32M stable, but i don't think it's safe to run 1.6v 24/7.
Do you think it's a mobo problem?
These are my bios settings for 3400 (not stable):
Can you see problems in this configuration?Code:10x340
PCI-E frequency: 90MHz
C.I.A.2 = disabled
Performance enhance = standard
DRAM DLL = option 1
ram at 680 4-5-5-15 2T (subs on auto). (i'll tighten them later on)
Voltage:
CPU: 1.550v
RAM: 1.8v
G MCH: +0.1v
PCI-E: +0.1v
FSB: normal
DDR2: normal
Also, is it viable to run EIST and C1E when overclocking?
i have the e2140 @ 2.8ghz rite now...
my board its a msi p6n sli
and i have 1gb team memory (timings acording to website are 5-5-5 15)
this is the core menu.. plz tell me what to put here to get 3.2ghz outta this cpu
:shrug:
spread spectrum
http://img217.imageshack.us/img217/9054/image003ku4.jpg
memory settings
http://img232.imageshack.us/img232/3900/image002dp5.jpg
and the cell menu
http://img215.imageshack.us/img215/8926/image001xe8.jpg
the part u dont see above.. says: eist (off) dot control (off) and cpu clock mode (auto, linked and manual)
so tell me what to put here to make this baby go to 3.2ghz
:shrug:
spread spectrum
memory settings
and the cell menu
Hi.
Is it ddr2-800 or 667?
Anyways: try loading defaults bios.
then put:
EIST / C1E: OFF
PCI-E: 100
FSB: 400
CPU Ratio: 8
DRAM: AUTO (timings on auto) - you'll work on timings later
CPU Voltage: 1.5v
Then run 2xSuperPi 32M. If you can't complete this, try lowering the fsb.
Anyone can post images for 200->266 and 266->333 pin mods for E2xxx?.
Thanks.:)
its ddr2 800mhz
thats why i wanna get up to 3.2ghz cuz then it will be like ddr2 400x2 (800) and cpu 400*8 and that sounds nice.. .
so i will turn off the c1e.. what about the HPET ?
keep everything i didn't mention at "default" :)
I'm planning to get a E2140 M0 soon. Is FSB wall a common problem for Pent Dual-Core or its just luck? I'm planning to get it over FSB 400. Thanks.
common problem at around 400MHz ( + - )
If you are planning 3200MHz, you should get a 2160 just to be sure
cheers
I don't have a problem with my E2140 at 3.2 GHz...Only bumped the vcore up, because something was causing it not to be stable, so i bumped voltages for nearly everything up, and it's stable. I need to do some tweaking.
VCore set to 1.35v
http://valid.x86-secret.com/show_oc.php?id=262110 <-- 24/7 settings...for now :D
http://valid.x86-secret.com/show_oc.php?id=262487 <-- suicide. I need to learn this board first. Damn DFI's. I'm CERTAIN that I could push this thing higher. I am only on air though.
http://img229.imageshack.us/img229/8616/cpuzrc5.gif
Those are my results on stock cooling, I don't wanna push it further until I get some better cooling.. has anyone else on stock cooling gotten it at 3ghz?
Here u go, some more of my results:
Superpi:
http://shrani.si/t/2U/11k/3FrES6v2/spi455.jpg
Cpuz:
http://valid.x86-secret.com/show_oc.php?id=265964
On CM Gemin2
@Yamcha, i was running 400fsb under stock. :D
Yes air cooled, CoolerMaster gemin2
where can i get an m0 in the us?
